anyone can help ? i see from the tutorial that it will turn off all the pump
thanks in advance
in feed mode , can i just stop the vortech pumps or tunze ?
chercm
Re: in feed mode , can i just stop the vortech pumps or tunz
Isn't stop and turn off the same?
chercm
i do not want the return pump to stop
Did you look at RAGen yet?
You can pick and choose which ports you want to turn on and off.
It also allows for assigning functions to each socket.
I suggest you look into it.
http://forum.reefangel.com/viewtopic.php?f=8&t=377
chercm
will it stop even if i am using the vortech RF unit ?
You can choose to stop it too. By default the RF module will put the Vortech into feeding mode too.
