Page 1 of 2
RA reboots using cloud wifi
Posted: Sat Jan 14, 2017 5:33 pm
by GermanDude
Hi there,
Has anyone had problems with the RA rebooting when you connect to the Cloud WIFI using the web Uapp?
As long as I do not close the browser and stay on the page it fine. If I reconnect using the Uapp the RA reboots and turns my ports back on that I turned off before. This happens with the iPhone, iPad or windows laptop.
Re: RA reboots using cloud wifi
Posted: Sat Jan 14, 2017 6:17 pm
I'm gonna try to replicate it.
I think someone else was having this same issue.
Posted: Sat Jan 14, 2017 6:30 pm
by GermanDude
Thanks,Roberto.
Posted: Tue Jan 17, 2017 5:17 pm
by GermanDude
Here is the code I am running. Still reboots RA+ when I use the Uapp.
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.DelayedOn( Port3,2 );
ReefAngel.StandardHeater( T1_PROBE,Port5,735,780 );
ReefAngel.PWM.SetDaylight( PWMSlope( 20,10,23,0,15,100,5,0 ) );
ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
Posted: Tue Jan 17, 2017 9:13 pm
I can't seem to be able to replicate this even using your code.
Uapp connects to the cloud server and when I close the browser, the controller is still up and no reboot.
Posted: Tue Jan 17, 2017 9:19 pm
I can refresh the page or close browser and reopen and it will still be there.
Posted: Tue Jan 17, 2017 9:33 pm
Is it after a certain period of time or it reboots even in the first minute of turning RA on?
Posted: Wed Jan 18, 2017 6:38 am
by GermanDude
It was doing this the second I opened the browser page for the Uapp.
I am at work so I will recheck tonight.
Posted: Wed Jan 18, 2017 7:44 am
by GermanDude
This ias the code loaded on the cloud wifi module.
In case it helps trouble shooting.
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
//char ssid[32];
//char pass[32];
//char username[16];
//char password[16];
unsigned long client_timeout = millis();
unsigned long wifi_connection = millis();
unsigned long serial_timeout = millis();
unsigned long led_blink = millis();
unsigned long MQTTReconnectmillis = millis();
boolean LED_status = false;
boolean PortalConnection = false;
boolean power_status = true;
boolean data_ready = false;
int status = WL_IDLE_STATUS;
WiFiServer server(2000);
WiFiClient client;
WiFiClient portalclient;
WiFiClient mqttclient;
void mqttcallback(char* topic, byte* payload, unsigned int length);
PubSubClient CloudClient(MQTTServer, MQTTPORT, mqttcallback, mqttclient);
String currentLine = ""; // make a String to hold incoming data from the client
void setup() {
Serial.begin(57600); // initialize serial communication
Serial1.begin(57600); // initialize serial communication
pinMode(6, OUTPUT); // set the LED pin mode
pinMode(7, OUTPUT); // set the LED pin mode
wdt_initialize();
wdt_enable();
void loop() {
wdt_reset();
status = WiFi.status();
while ( status != WL_CONNECTED) {
digitalWrite(6, true);
digitalWrite(7, false);
if (millis() - wifi_connection > 1000)
Serial.print("Attempting to connect to Network named: ");
Serial.println(WIFI_SSID); // print the network name (SSID);
if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
server.begin(); // start the web server on port 2000
printWifiStatus(); // you're connected now, so print out the status
digitalWrite(6, false);
digitalWrite(7, true);
client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println(F("new incoming client")); // print a message out the serial port
while (client.connected()) { // loop while the client's connected
if (millis() - client_timeout > 2000) client.stop();
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
Serial1.write(c); // send to Reef Angel
if (Serial1.available())
char c = Serial1.read();
//Serial.write(c);
currentLine += c;
if (currentLine.length() == 255) {
SendData();
if (millis() - serial_timeout > 400)
if (currentLine.length() > 0) {
SendData();
Serial.println();
client.println();
if (millis() - led_blink > 50)
LED_status = !LED_status;
digitalWrite(6, LED_status);
// close the connection:
client.stop();
Serial.println(F("incoming client disconnected"));
while (Serial1.available())
currentLine += c;
if(c==10) data_ready=true;
if (millis() - serial_timeout > 200 || data_ready)
data_ready=false;
// Serial.print(currentLine);
if (currentLine.startsWith("GET"))
PortalConnection = true;
Serial.println(F("Connecting to Portal Server"));
if (portalclient.connect(PortalServer, 80)) {
Serial.println(F("Connected"));
// Make a HTTP request:
portalclient.print(currentLine);
portalclient.println(F(" HTTP/1.1"));
portalclient.println(F("Host: forum.reefangel.com"));
portalclient.println(F("Connection: close"));
portalclient.println();
Serial.println(F("Failed to connect"));
if (currentLine.startsWith("CLOUD:"))
//Serial.print(currentLine);
if (currentLine.length() < 32)
if (CloudClient.connected())
//Serial.println(F("Publishing "));
currentLine.replace("CLOUD:", "");
char pub_buffer[sizeof(CLOUD_USERNAME) + 5];
sprintf(pub_buffer, "%s/out", CLOUD_USERNAME);
char pub_msg[currentLine.length() + 1];
currentLine.toCharArray(pub_msg, currentLine.length() + 1);
CloudClient.publish(pub_buffer, pub_msg);
Serial.print(F("Error on incoming data: "));
Serial.println(currentLine.length());
currentLine = "";
while (portalclient.available()) {
char c = portalclient.read();
// Serial.write(c);
if (PortalConnection && !portalclient.connected()) {
// Serial.println();
Serial.println(F("Disconnecting from Portal Server"));
portalclient.stop();
CloudClient.loop();
if (millis() - MQTTReconnectmillis > 5000)
if (!CloudClient.connected())
char sub_buffer[sizeof(CLOUD_USERNAME) + 6];
Serial.println(F("MQTT Connecting..."));
sprintf(sub_buffer, "RA-%s", CLOUD_USERNAME);
if (CloudClient.connect(sub_buffer, CLOUD_USERNAME, CLOUD_PASSWORD))
sprintf(sub_buffer, "%s/in/#", CLOUD_USERNAME);
Serial.println(F("MQTT succeeded"));
CloudClient.subscribe(sub_buffer);
Serial.println(F("MQTT failed"));
CloudClient.disconnect();
if (analogRead(0) < 600 && power_status)
power_status = false;
if (analogRead(0) > 600 && !power_status)
void SendData()
currentLine = "";
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial1.print("cloud:");
for (int a=0;a<length;a++)
Serial1.write(payload[a]);
Serial.write(payload[a]);
Serial1.print(" ");
Serial.println();
void wdt_initialize()
GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
GCLK_GENCTRL_GENEN |
GCLK_GENCTRL_SRC_OSCULP32K |
GCLK_GENCTRL_DIVSEL;
while (GCLK->STATUS.bit.SYNCBUSY); // Syncronize write to GENCTRL reg.
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
GCLK_CLKCTRL_CLKEN |
GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CTRL reg.
WDT->CONFIG.reg = WDT_CONFIG_PER(0xA); // 0xA = 8192 ms
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CONFIG reg.
WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX19/au2AykFSeuvh7Ef0WBhNw2fGDTBJTmA=
// RA_STRING2=U2FsdGVkX18OMaDMIUP5GZQUBkPiWBixOeo/eh7U/b8=
// RA_STRING3=Dakota
Posted: Thu Jan 19, 2017 12:28 pm
Let's try this....
We are going to use the cloud wifi attachment and the USB-TLL cable.
1. Connect the cloud wifi to the usb ttl cable. Black wire to the right. This should power the unit on.
2. Using the arduino ide, open serial monitor and make sure you are using 57600 baud rate.
3. Open Uapp on your browser, it should print some stuff on serial monitor window.
Paste here.
Posted: Thu Jan 19, 2017 4:23 pm
by GermanDude
Ok, cant copy and past so I will type it.
cloud wifi connected with USB-TLLcable on com 3 57600baud. As soon as i open the serial monitor I get this:
GET /r99 HTTP/1.1
Host: 73.148.165.18:2000
This repeats forever. Now I open the Uapp on the web and I get:
GET /r99 HTTP/1.1
cloud:all:0 GET /r99 HTTP/1.1
GET /r99 HTTP/1.1
This repeats every time I open the Uapp.
Hope this helps.
Posted: Thu Jan 19, 2017 6:05 pm
It looks good as far as the cloud command.
I do see the pings for the Client suite.
Can you turn it off and see if it makes any difference?
It should show only "cloud:all:0"
The other requests are coming from the Client suite.
Posted: Thu Jan 19, 2017 8:18 pm
by GermanDude
Do you mean the Reef Angel client suite , that runs the services in the background, by Dave Molton?
Posted: Thu Jan 19, 2017 9:21 pm
correct.
Shut that service off and see if that makes any difference on the log and rebooting.
Posted: Fri Jan 20, 2017 5:19 pm
by GermanDude
Followed your directions and this is what I see in the serial monitor:
cloud:all:0
Still reboots RA when I connect with the Uapp.
Posted: Fri Jan 20, 2017 5:28 pm
Ok, so let's try the other end now.
Plug the usb-ttl on RA instead of wifi attachment.
Open serial monitor at 57600 baud and make sure that you have Both CR & LF selected.
Then, send this string "cloud:all:0 ". Note that there is a space after 0.
Paste the log.
Does it reboot RA?
Posted: Fri Jan 20, 2017 6:30 pm
by GermanDude
Yes it rebooted. As a matter of fact it rebooted when I hooked up the usb to the pc, started the IDE and started the serial monitor. I received data after each reboot and after I send the cloud:all: command like this;
CLOUD:SAL:0
CLOUD:PHE:0
CLOUD:PAR:0
CLOUD:CEXP0:0
CLOUD:CEXP2:0
CLOUD:ATOLOW:1
CLOUD:BID:1
CLOUD:PWMD:100
CLOUD:PWMDO:255
CLOUD:R:251
CLOUD:ROFF:255
CLOUD:T1:766
CLOUD:PH:776
Posted: Fri Jan 20, 2017 7:17 pm
I just can't replicate the problem
Posted: Fri Jan 20, 2017 7:27 pm
The controller does reboot everytime the com port is opened. So it is normal for it to reboot when you plug cable or open serial monitor.
One thing odd in that log is the fact that it is showing SAL, PHE, PAR and other stuff that wasn't supposed to be there when you reboot RA.
This is what I get when I reboot RA with the same code:
CLOUD:BID:1
CLOUD:PWMDO:255
CLOUD:PWMAO:255
CLOUD:R:235
CLOUD:ROFF:255
CLOUD:PH:438
And this is what I get when I send the cloud:all:0 command:
CLOUD:ATOLOW:0
CLOUD:ATOHIGH:0
CLOUD:EM:0
CLOUD:EM1:0
CLOUD:REM:0
CLOUD:BID:1
CLOUD:AF:0
CLOUD:SF:0
CLOUD:PWMD:0
CLOUD:PWMA:0
CLOUD:PWMDO:255
CLOUD:PWMAO:255
CLOUD:R1:0
CLOUD:ROFF1:0
CLOUD:RON1:0
CLOUD:R2:0
CLOUD:ROFF2:0
CLOUD:RON2:0
CLOUD:R3:0
CLOUD:ROFF3:0
CLOUD:RON3:0
CLOUD:R4:0
CLOUD:ROFF4:0
CLOUD:RON4:0
CLOUD:R5:0
CLOUD:ROFF5:0
CLOUD:RON5:0
CLOUD:R6:0
CLOUD:ROFF6:0
CLOUD:RON6:0
CLOUD:R7:0
CLOUD:ROFF7:0
CLOUD:RON7:0
CLOUD:R8:0
CLOUD:ROFF8:0
CLOUD:RON8:0
CLOUD:ALARM:0
CLOUD:PWMD2:0
CLOUD:PWMA2:0
CLOUD:PWMD2O:0
CLOUD:PWMA2O:0
CLOUD:WL:0
CLOUD:WL1:0
CLOUD:WL2:0
CLOUD:WL3:0
CLOUD:WL4:0
CLOUD:HUM:0
CLOUD:DCM:0
CLOUD:DCS:0
CLOUD:DCD:0
CLOUD:DCT:0
CLOUD:PWME0:0
CLOUD:PWME1:0
CLOUD:PWME2:0
CLOUD:PWME3:0
CLOUD:PWME4:0
CLOUD:PWME5:0
CLOUD:PWME0O:0
CLOUD:PWME1O:0
CLOUD:PWME2O:0
CLOUD:PWME3O:0
CLOUD:PWME4O:0
CLOUD:PWME5O:0
CLOUD:AIW:0
CLOUD:AIB:0
CLOUD:AIRB:0
CLOUD:RFM:0
CLOUD:RFS:0
CLOUD:RFD:0
CLOUD:RFW:0
CLOUD:RFRB:0
CLOUD:RFR:0
CLOUD:RFG:0
CLOUD:RFB:0
CLOUD:RFI:0
CLOUD:RFWO:0
CLOUD:RFRBO:0
CLOUD:RFRO:0
CLOUD:RFGO:0
CLOUD:RFBO:0
CLOUD:RFIO:0
CLOUD:IO:0
CLOUD:LEAK:0
CLOUD:C0:0
CLOUD:C1:0
CLOUD:C2:0
CLOUD:C3:0
CLOUD:C4:0
CLOUD:C5:0
CLOUD:C6:0
CLOUD:C7:0
CLOUD:R:235
CLOUD:ROFF:255
CLOUD:RON:0
CLOUD:T1:0
CLOUD:T2:0
CLOUD:T3:0
CLOUD:PH:439
CLOUD:ORP:0
CLOUD:SAL:0
CLOUD:PHE:0
CLOUD:PAR:0
CLOUD:CEXP0:0
CLOUD:CEXP1:0
CLOUD:CEXP2:0
CLOUD:CEXP3:0
CLOUD:CEXP4:0
CLOUD:CEXP5:0
CLOUD:CEXP6:0
CLOUD:CEXP7:0
Posted: Fri Jan 20, 2017 8:15 pm
by GermanDude
Odd. I did load a new program on it tonight before I did your test. It is the same code, I just added a ATO float switch code to it.
Keep in mind that it does NOT reboot if I use the Reef Angel client or the portal. Only the web based Uapp. One more thing, I cannot connect with the standalone Uapp on my iPhone or iPad at all, only the web Uapp. Of course that reboots the controller.
Is nobody else having this problem?
I know this cloud wifi is new, so I am hoping it is a bug somewhere.
Posted: Fri Jan 20, 2017 8:21 pm
The uapp for ios is an older release and it will not connect to the cloud server.
I'm trying to fix a few bugs before I release it a new version.
I know it doesn't reboot when you use the standard ip/port connection. It's something related to the cloud protocol, but I just can't replicate to see where it is.
Posted: Fri Jan 20, 2017 8:29 pm
by GermanDude
No problem.
Let me know if you want me to do more testing. I love this stuff ( IT guy during the day).
Posted: Sat Jan 21, 2017 5:17 am
by GermanDude
current code on my RA+
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.StandardHeater( T1_PROBE,Port5,770,780 );
ReefAngel.PWM.SetDaylight( PWMSlope( 20,10,23,0,50,100,5,0 ) );
//if (ReefAngel.HighATO.IsActive() ) ReefAngel.Relay.Off( Port1 );
ReefAngel.Relay.Set(Port1,ReefAngel.LowATO.IsActive() );
// RA_STRING1=U2FsdGVkX1+k9UBojA2Zl/cGlo+KsPGdeqVYyPkLiZ4ANu8kYtgn0na/dT0wET6s
// RA_STRING2=U2FsdGVkX19G+/qidwTF5uA/QEK9x7ZM12MiXZWqtO8=
Why are they two copies of #include <InternalEEPROM.h> ?
Posted: Sat Jan 21, 2017 10:41 am
Probably an oversight I made, but it doesn't hurt any.
I still cannot replicate the problem.
Just for the hell of it, the only thing different is that I don't use the relay box to power the head unit.
Can you try that code with the controller head unit alone powered with the USB power cable and see if it reboots too?
Posted: Sat Jan 21, 2017 11:25 am
by GermanDude
Yes I can.
Water change time for my tank is tomorrow which will give me the perfect opportunity to test just the head unit.
I will return with the results.
Posted: Sat Jan 21, 2017 12:01 pm
by GermanDude
Never mind. I went ahead and tested.
RA+, Cloud Wifi , PH probe, Temp probe and 1 float switch connected. Disconnected relay box and power head unit with USB.
Opened web page to the Uapp and....head unit rebooted.
Posted: Wed Jan 25, 2017 6:32 pm
by GermanDude
I have noticed when I use the webwizard and compile code it gives me this message at the end of a succesfull compile:
Dimming Signal
Cloud Wifi Attachment
Wifi Attachment
2014 Main Screen
Standard Menu
Standard Menu
Standard Menu
Standard Menu
===info ||| Sketch uses {0} bytes ({2}%%) of program storage space. Maximum is {1} bytes. ||| [66646 253952 26]
===info ||| Global variables use {0} bytes ({2}%%) of dynamic memory, leaving {3} bytes for local variables. Maximum is {1} bytes. ||| [3282 8192 40 4910]
Progress: 100.00%
Your code was compiled sucessfully.
Is it normal to have both the Cloud Wifi Attachment and the Wifi Attchment in the code? I only pick the Cloud Wifi Attachment from the wizard since that is what I have.
Posted: Thu Jan 26, 2017 2:50 am
Yeah. It is normal.
Posted: Thu Jan 26, 2017 9:51 am
by GermanDude
Ok, thanks.
Were you able to find anything that would cause the rebooting of the RA yet?
Posted: Thu Jan 26, 2017 10:26 am
Sorry, I didn't have time.
I'm in Germany in fact since last Saturday.
I'll check some more next week when I get back to USA.
