How to properly set or adjust peak wave
Posted: Sun Feb 12, 2017 10:05 am
Hi, odd question.
Is it possible to adjust or set, maybe predict, when the tip of the reef crest or wave pattern will hit during the day? Not sure how to add a image but using the PWMA graph on the portal, http://forum.reefangel.com/status/chart ... ilter=PWMA, my pattern appears to be peaking during the evening between 2 and 4 AM when I'd like it a lot calmer - has does my anemone's.
I made a few changes over the last couple of weeks to my code so not sure what it was that set it to this timeline if truth be told. I've been trying to find a suitable wave pattern for a mostly soft tank, 40 breeder, that will stop two of my rose bubble tips from moving around. I've tried turning on one side, then the other, every 12 hours, then this which was doing ok until I noticed at night everything is storming high. Figured I'd ask. Also, I thought I saw in the portal graphs showing wave patterns. Maybe lagoon isn't right or I am using it wrong. I just need the ideal one to let the hammers, and 'nems wave and the Xenia not being blown over.
Thanks for any tips or guidance. Maybe this will force me to uncrate my 240 gallon in the garage and start working on it. The anenomes will probably thank me for it later. Worst purchase ever - started with one about 7 years ago and now I have 6
The 40 is too small.
Thanks again.
![Sad :(](./images/smilies/icon_e_sad.gif)
Thanks again.
#include <Moon.h>
#include <Tide.h> // testing for tide control
#include <SunLocation.h>
Tide tide; // testing for tide control
SunLocation sun;
byte PWMChannel[6];
ReefAngel.Use2014Screen();
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 819 );
ReefAngel.Relay.On( Port1 ); // skimmer
// ReefAngel.Relay.On( Port4 ); // LED Fans
ReefAngel.Relay.On( Port5 ); // RW 4 left side facing tank
ReefAngel.Relay.On( Port6 ); // RW 4 right side facing tank
tide.Init(40, 5, 20);
tide.SetWaveLength(12*SECS_PER_HOUR);
sun.Init(38.5791, 121.1939); // Rancho Cordova, Ca
ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
ReefAngel.StandardLights( Port3,9,0,22,0 ); // LED bar
ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
ReefAngel.StandardHeater( Port7,750,800 );
ReefAngel.StandardHeater( Port8,750,800 );
// Channel 0 (1000mA max) - 5 Neutral White
PWMChannel[0]=PWMParabola(9,0,21,0,0,80,0);
// Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
PWMChannel[1]=PWMParabola(9,0,21,0,0,85,0);
// Channel 2 (700mA max) - 12 Lime
PWMChannel[2]=PWMParabola(9,0,21,0,0,55,0);
// Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
PWMChannel[3]=PWMParabola(9,0,21,0,0,70,0);
tide.isIncoming();
byte tideSpeed = tide.CalcTide();
byte w_risehour = sun.GetRiseHour();
byte b_risehour = sun.GetRiseHour(); //Starting Blues an hour before
byte riseminute = sun.GetRiseMinute();
byte w_sethour = sun.GetSetHour();
byte b_sethour = (sun.GetSetHour()) + 1;
byte setminute = sun.GetSetMinute();
char label_rise_hr = sun.GetRiseHour();
char label_rise_min = sun.GetRiseMinute();
char label_set_hr = sun.GetSetHour();
char label_set_min = sun.GetSetMinute();
byte vtDuration = InternalMemory.RFDuration_read();
CheckCloud();
sun.CheckAndUpdate();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
ReefAngel.DCPump.Threshold = 40;
if (hour() >= 0 && hour() < w_risehour) {
ReefAngel.DCPump.SetMode(Lagoon, tideSpeed, vtDuration);
else if (hour() >= w_sethour && hour() <= 24) {
else if (hour() >= w_risehour && hour() <= w_sethour)
ReefAngel.DCPump.SetMode(LongPulse, tideSpeed, vtDuration);
ReefAngel.Portal( "saf1" );
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 45
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 4
#define End_Cloud_Before NumMins(21,30)
#define Lightning_Change_per_Cloud 65
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
//#define Actinic_Channels B000001 // Original sample code values
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
//#define Daylight_Channels B000010 // Original sample code values
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
