Litany of strange goings on...
Posted: Fri Mar 24, 2017 5:30 pm
by skehole
I have a variety of things currently happening and would love some assistance.
Switched router and modem and suddenly I could only access app from OUTSIDE my home wifi network.
To make things stranger I finally broke down and updated my wifi module and I can collect graph data and get them displayed in my home network and outside lte network, but cannot manipulate relays, or refresh my ph and temp while on my home network.
I recently switched from in code locations to internal memory on my ra+. All my relays are behaving as programmed according to my app, but my temperature changes (from 77.5-8, to 77-77.5)are not taking place according to my relay and graph data.
Let me know if there's anything further that is needed to figure out what's going on. I am not a tech savvy person. I am a tile contractor and work with my hands. I am starting to wonder if this platform was not the right choice for my skill set lol.
Re: Litany of strange goings on...
Posted: Fri Mar 24, 2017 6:37 pm
by GugsJr
Can you copy and post your code so we can make sure it's ok? Can you access the portal on the web? Are you trying to use the App from your phone/table?
Posted: Fri Mar 24, 2017 6:40 pm
Did you also change internet provider.
I have comcast and cannot access my outside ip when I'm in my own wifi network.
They use a router that doesn't allow loopback.
I created two profiles on Android app.
One for when I'm home and one for when I'm outside.
Posted: Fri Mar 24, 2017 6:56 pm
by skehole
rimai wrote:Did you also change internet provider.
I did not change providers no.
Also, I went in to internal memory via the app, changed the temp parameters, then changed them back to where I wanted them and they seemed to recognize the new numbers for some reason.
I will post my code once my kids are asleep lol. Although it is EXTREMELY rudimentary and was solely generated through the wizard
Posted: Fri Mar 24, 2017 7:00 pm
by skehole
GugsJr wrote:Can you copy and post your code so we can make sure it's ok? Can you access the portal on the web? Are you trying to use the App from your phone/table?
Will post the code as mentioned previously but no, the portal will not allow me to change my relays.
Taken literally seconds apart
Posted: Fri Mar 24, 2017 7:02 pm
by skehole
here's the code
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.Portal( "skehole" );
ReefAngel.DDNS( "fish tank" ); // Your DDNS is skehole-fish tank.myreefangel.com
Posted: Sat Mar 25, 2017 12:15 pm
by skehole
And never mind on the controllers int memory working on the heater.
Posted: Sat Mar 25, 2017 12:22 pm
by GugsJr
That's good to see.
Posted: Sat Mar 25, 2017 7:05 pm
by skehole
GugsJr wrote:That's good to see.
What is? Lol....am I missing something?
Posted: Sat Mar 25, 2017 7:45 pm
by GugsJr
Looks like your temps are working. They are going to fluctuate a bit because it takes time for them to go on and go off. You can set the range a bit lower then 77 if you want it to get to 77
Posted: Mon Mar 27, 2017 12:50 pm
by skehole
Why are my relays on the portal not reflecting the relays on the app?
Posted: Mon Mar 27, 2017 12:57 pm
by GugsJr
The labels? Or you mean you can't access the relays from the portal.
If it's the labels you have to change the names in the portal and download them to the app.
If you can't access the relays from the portals. Probably means your port forwarding isn't set up correctly.
Posted: Mon Mar 27, 2017 3:59 pm
by skehole
GugsJr wrote:The labels? Or you mean you can't access the relays from the portal.
if you compare the two pictures I posted of my app screen shot and the portal photo, the auto, on , and off do not correlate from one to the other.
Posted: Mon Mar 27, 2017 4:02 pm
by skehole
And honestly, I don't care too much as I use the U-App exclusively but just wanting things to work either way just in case
Posted: Mon Mar 27, 2017 4:34 pm
by GugsJr
Oh I see that, honestly I'm not sure. Roberto probably would be the person you need help from.
Posted: Mon Mar 27, 2017 7:18 pm
It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
Posted: Wed Mar 29, 2017 12:18 am
by skehole
rimai wrote:It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
That's strange seeing as how I posted the screenshot on the 24th. What would cause that to happen? Port forwarding is working on my U-App
Posted: Wed Mar 29, 2017 10:45 am
Did you change code around that time?
Posted: Thu Mar 30, 2017 8:58 am
by skehole
rimai wrote:Did you change code around that time?
Yes I switched to internal memory coding. The code should be listed above. Also noticing that my graphs will not allow me to go beyond 1 or 12 hour time periods
Posted: Thu Mar 30, 2017 9:37 am
It is because your last data was 03/23 and it only keeps for 7 days.
Tomorrow you won't have data.
Posted: Thu Mar 30, 2017 9:38 am
I think it is because of the space on the ddns.
Try removing that space.
Posted: Thu Mar 30, 2017 11:26 am
by skehole
rimai wrote:I think it is because of the space on the ddns.
Can you show me where you're talking about? I assume it's at the end, but I'm not sure what space you're talking about.
Also, this was generated via the wizard and was not altered in any way.
Posted: Thu Mar 30, 2017 1:27 pm
Yes, the space on your ddns line.
Use fishtank without a space.
HTTP protocol doesn't understand spaces.
Posted: Thu Mar 30, 2017 2:40 pm
by skehole
rimai wrote:Yes, the space on your ddns line.
Gotcha. Thanks I will try when I get back in town.
Posted: Fri Mar 31, 2017 1:09 pm
by skehole
That appears to have done it. Thanks!
