ATO high/low as failsafe
jcjrogers
I want to use my float switches as a fail safe for my Water Level Expansion that will run my ATO. It looks like a simple If/Then Statement should do it, but "Is on" and "Is off" are grayed out, and I don't know what other option to use.
Re: ATO high/low as failsafe
I think you are past the point of using the wizard a long time ago
You should just edit your code to accommodate what you need now.
I think the best way is to use the waterlevelato function for the ATO and force it to off if there is a float trigger.
Something like this:
ReefAngel.WaterLevelATO(Port1);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
jcjrogers
Ok, just getting back to this. Regarding the Wizard, I just use it to generate specific lines of code now, and then copy/paste into my saved sketch. I'm doing all of this on the bench, hoping to get it right before installation (planned for today or tomorrow). I can't test the high ATO as I'm using the Multi-channel Water Expansion module for my main ATO, and it hasn't been attached or calibrated.rimai wrote:I think you are past the point of using the wizard a long time ago
Something like this:Code: Select all
ReefAngel.WaterLevelATO(Port1); if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
On the low ATO side, I'm trying to shut-off my main pump as I want this failsafe to protect the pump and warn me that the water level has gotten too low. I've tried to code turning-off the main pump, but the main pump is just always off. Here is what I added:
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port6); /// Failsafe to turn-off ATO pump if water level too high.
if (!ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port4); /// Failsafe to turn-off Main pump if water level too low.Code: Select all
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit;
InternalMemory.OverheatTemp_write( 840 );
//*ReefAngel.Relay.On( Port1 ); - place holder for Webwizard. Using ActinicLights code for Port 1
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port2 );
ReefAngel.StandardHeater1( Box1_Port2 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port2 ) );
ReefAngel.StandardHeater1( Port5 );
ReefAngel.WaterLevelATO( 1,Port6 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.StandardFan1( Port8 );
if ( ReefAngel.Params.PH > 840 ) ReefAngel.Relay.Off( Port6 );
ReefAngel.WaterLevelATO( 2,Box1_Port4,5,95,14400 ); // hard codes ATO reservoir settings since only one available in Uapp.
MyOwnStandardLights(Port1,-InternalMemory.ActinicOffset_read()); // Calls my new offset to allow negative offset.
ReefAngel.CloudPortal();
/// Code below makes neg. offset for T5's.
void MyOwnStandardLights(byte Relay, int MinuteOffset)
int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-MinuteOffset;
int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+MinuteOffset;
ReefAngel.StandardLights(Relay,
onTime/60,
onTime%60,
offTime/60,
offTime%60
// RA_STRING1=U2FsdGVkX1/MRai+5HT5Qq9ZfbEK1mzFXKwT07B7oyM=
// RA_STRING2=U2FsdGVkX1+PuVSO4WlfFCjqa//mhJqdV9c4vId+V1I=
// RA_STRING3=Chloe's House-2.4
The ! sign means not.
When the float is not floating, it is active and when it is floating, it is not active.
So, you should remove the ! sign when using it as low ciut off switch.
jcjrogers
Update: with the code below, clearing ATO doesn't reinstate Port 4 (main pump). Rebooting does reinstate Port 4, but moving the float to an inactive position doesn't reinstate (probably a good thing as when the main pump turns off, the sump level will rise, making inactive pretty quickly. It seems rebooting to reinstate is a little cryptic, but I'm not sure there is better logic. I don't really want the main pump to go back and forth on/off as water leaves and then returns to sump. Thoughts?
if ( ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port6);
if ( ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port4);
onTime/60,
onTime%60,
offTime/60,
offTime%60
jcjrogers
I accidentally posted the first code that didn't work. The new code didn't work either, until I reset the controller. See response above.rimai wrote:The ! sign means not.
jcjrogers
I guess "Clear ATO" is resetting ports identified as "ATO" as opposed to doing something with the ATO code. Since my main pump is an always on relay (not a water level/ATO), the only way to reset is to reset the controller... makes sense.
Naptalene
I had the same problem with a similar setup
I just had to add an else statement and it's working now.
Mine is
You can put in the ! To flip the logic..... or just
Flip the floats switches lol.
Weird thing is my old code from years ago didn't need that else.
Mine is
If (ReefAngel.ATOHigh.isActive)
ReefAngel.Relay.Off(your return pump port here);
else (ReefAngel.Relay.On(your return pump port here);
