The libraries are stored in your Documents folder under the arduino folder. In order to have multiple versions of the libraries installed and using, you must create multiple folders for the versions and switch back and forth between them when you want to use them.
For this example, we will use the latest version of the libraries for the RA+ and then version 1.0.4 for the standard RA (I forget what the latest version that the standard RA can run). I am assuming that you already have the latest libraries installed on your computer, if not, update them using the arduino app.
- You will need to download the version 1.0.4 from the github repository. (https://github.com/reefangel/Libraries/ ... v1.0.4.zip)
- Unzip the file in a temporary folder (like your downloads folder). That will create a folder called Libraries-1.0.4.
- Rename that folder to libraries-1.0.4 (change the uppercase L to a lowercase l).
- Move that Libraries-1.0.4 folder to the Documents/arduino folder. You will now have a libraries folder and a libraries-1.0.4 folder.
Now you have 2 versions of the libraries installed on your computer.
To switch between the different versions of the libraries, you must make sure that the Arduino app is closed before you attempt to switch versions. You will need to rename the version you are using to its full name and then the version you want to use to just libraries.
Example:
You are currently on the latest 1.1.3 and want to switch to 1.0.4.
- You will exit out of the Arduino app.
- Rename 'libraries' to 'libraries-1.1.3'.
- Rename 'libraries-1.0.4' to 'libraries'
- Start Arduino app
You are now running version 1.0.4 of the libraries.
NOTE: The arduino app automatically checks for the latest version of the libraries and prompts you to update them. If you are running version 1.0.4, make sure you do not update them to the latest. Otherwise, you will just need to re-download the version 1.0.4 and repeat the steps listed above.
To switch back to the latest version 1.1.3, you will just do this:
- Exit the Arduino app
- Rename 'libraries' to 'libraries-1.0.4'
- Rename 'libraries-1.1.3' to 'libraries'
- Start Aduino app
You are good to go now for switching between library versions. You could do this for multiple versions of the libraries if you wanted.
If you forget which version of the libraries you are currently setup to use, just goto the "Tools-->Reef Angel Libraries Version" menu and it will display the version in the output window.
The only thing I will also add, since you have a RA and a RA+, is you will want to choose the proper Controller from the "Tools-->Board" menu. Otherwise, you will not be able to connect to the one of the controllers.
All of your sketches will be available no matter what version you are running of the libraries.
It's pretty straightforward. Have fun!!
