I have two bits of strange behavior that I haven't been able to figure out.
1. Occasionally, my RA will stop reading temperature and will report out at 0. Sometimes a simple reboot from the iOS app fixes it, sometimes unplugging it does it. Other times it requires doing that repeatedly. This is a problem since it stops running my heaters. Last time this happened the tank dropped 4 degrees before I realized it happened.
2. The portal isn't displaying the correct PWM outputs for my light. I'm actually not using it anymore, but I'm wondering if there's something more systemic causing #1 and this one.
Strange Behavior
icecool2
icecool2
Re: Strange Behavior
icecool2
Darn.... I have it plugged in via an extension cable. Maybe I'll try and pull that first and see if it helps.
