Two float switch on the same port
rrodriguess
Post by rrodriguess »
Hi there
I use float switchs as a fail safe for both my Automatic Water Change and my "roberto flow". It is well know that float switch has a short life, and sooner or later tends to fail.
Question. Can I connect two float switch in the same connector? I mean, just attaching the electrical cables and using the same "port". This way, if a float switch fails in the AWC, I still have the other one working and preventing a flood.
My superficial and ridiculous knowledge says that as they work with electrical signals, would be no problem doing that. Am I right?
Best regards
Rafa
Re: Two float switch on the same port
Do you mean both in serial?
Can you draw something and post just to be sure?
rrodriguess
Roberto
This way: They would monitor the same spot, one backing up the other.
sounds like he wants them to be run in parallel.
yeah. It should work just fine
rrodriguess
Tks Roberto
Tks Binder
tkeracer619
Post by tkeracer619 »
Float switches shouldn't fail often.
Most people put way too much voltage or current through switches.
Float switches always need to be in series. If you are in parallel and one float gets stuck in the on position the other will not be a fail safe as current will have a way to flow.
