Page 1 of 2
Alexa Control
Posted: Sun Dec 10, 2017 8:41 pm
by Seedlessone
Has anyone figured out a way to say simple commands to the RA via Echo? I would like to get some simple commands working. Mainly, feed mode. Maybe using the web command, /mw?
Re: Alexa Control
Posted: Sun Dec 10, 2017 9:16 pm
I don't have one, but Google search leads to creating an Alexa skill, which requires you to sign up for a dev account.
After signing up and creating the skill, you should be able to send commands to RA
Re: Alexa Control
Posted: Tue Dec 12, 2017 7:10 am
by Seedlessone
This is the correct feed mode command?
http://ipaddress:2000/mf
Re: Alexa Control
Posted: Tue Dec 12, 2017 10:16 am
for feeding, yes.
Re: Alexa Control
Posted: Wed Dec 13, 2017 3:04 pm
That would be sweet. Would make life so much easier. I could ask my wife to feed the fish now
Re: Alexa Control
Posted: Sun Jan 14, 2018 11:11 am
by luckybaker4
Seedlessone - are you working on this? I was going to pick this up as a side project but ran across this thread.
Re: Alexa Control
Posted: Fri Jan 19, 2018 11:33 am
by Zexston
Don’t know if this helps, but it came across my YouTube feed:
https://youtu.be/3TaLlI4BqeI
It shows the setup process for an Alexa skill and RPi out the serial port.
Re: Alexa Control
Posted: Fri Mar 23, 2018 4:34 pm
Who wants to beta test?
pm me your email address that is linked to your alexa account.
Re: Alexa Control
Posted: Mon May 07, 2018 5:46 pm
by Seedlessone
Roberto does it again. First controller on the market with Alexa support?
Its working great on my end so far!! Thanks
Re: Alexa Control
Posted: Mon May 07, 2018 6:09 pm
by Seedlessone
The only command that hasn't worked yet, is "Alexa what is the temperature of ____". I've change the probe name a few times to make sure the echo could understand me. Its named "fish tank"now and she has no clue what I'm asking. LOL
Re: Alexa Control
Posted: Mon May 07, 2018 6:26 pm
I used display tank with success
Re: Alexa Control
Posted: Mon May 07, 2018 6:50 pm
by Seedlessone
rimai wrote:I used display tank with success
Hmmm. Just changed probe 1 name to display tank.
"Alexa, what is the temperature of display tank?"
"Sorry, I didn't find display tank"
Re: Alexa Control
Posted: Mon May 07, 2018 8:33 pm
Did you change it on the portal or the Alexa app?
When I changed names, I changed them in the portal then I went to Alexa app and deleted the old name device. Discovered devices again to find the one you deleted. It will come with the new name.
I didn't test if there was an easier way.
Re: Alexa Control
Posted: Tue May 08, 2018 8:24 pm
by Seedlessone
rimai wrote:Did you change it on the portal or the Alexa app?
Good to go now. Didnt even think about pulling the new device name into alexa app....duh!
Re: Alexa Control
Posted: Tue May 08, 2018 8:38 pm
I know you can change names on the Alexa app, and theoretically it should work without having to rename in the portal, but I didn't test.
Re: Alexa Control
Posted: Sat May 12, 2018 8:16 am
Is there a list of the commands anywhere?
Re: Alexa Control
Posted: Sat May 12, 2018 2:06 pm
The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
What is the temperature of ...
Re: Alexa Control
Posted: Sat May 12, 2018 5:16 pm
by mav3rick478
I know this is an Alexa thread but is there any chance of the RA working with Google Assistant?
Sent from my Pixel XL using Tapatalk
Re: Alexa Control
Posted: Sat May 12, 2018 8:00 pm
I would need to look into how google handles everything.
Don't hold your breath though. It may take a while.
Re: Alexa Control
Posted: Mon May 14, 2018 7:15 pm
by Seedlessone
rimai wrote:The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
Certainly not trying to rush, but what sort of timeline do you have on feeding and water change mode?
So far it has been 100%!!
Re: Alexa Control
Posted: Tue May 15, 2018 5:39 am
Feeding mode would be most useful!
Re: Alexa Control
Posted: Sun May 20, 2018 12:04 am
Can you test feeding and water change mode?
You will need to discover devices again to enable the two modes.
Re: Alexa Control
Posted: Sun May 27, 2018 8:15 pm
Feeding mode worked nicely
Re: Alexa Control
Posted: Tue Jun 05, 2018 6:37 pm
by 89delta
So i'm trying to enable the skill and after the amazon login screen it takes me to the authorization page i guess and it remains blank. Any ideas?
Re: Alexa Control
Posted: Tue Jun 05, 2018 9:51 pm
I wasn't able to replicate.
I tried it on a new phone with a new amazon account.
Re: Alexa Control
Posted: Fri Oct 26, 2018 11:45 pm
by icecool2
I just tried this myself and ran into an error trying to login.
I confirmed my username and password were correct by logging into the forum to double check. Same error comes up using Alexa app, Safari and Firefox. This is on ios12, not that I think that’s the issue.
Re: Alexa Control
Posted: Tue Oct 30, 2018 9:50 am
by icecool2
Just tried again hoping this would clear itself.... no dice. Still the same issue.
Re: Alexa Control
Posted: Tue Oct 30, 2018 10:40 am
I just tested the amazon/reef angel skill linking and it went through just fine.
Try resetting the forum password and try again.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:00 pm
by icecool2
That did the trick! Got the skill installed, but I'm getting device is unresponsive. I have the Wifi adapter, not the cloud adapter. Is that a problem?
It also only discovered my second relay box, not the first.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:09 pm
It actually only works with RA*.
I never tested with the cloud wifi attachment. It should work, but definitely not with the regular wifi attachment.
