Expansion module
Expansion module
I just hooked up the expansion hub and and plugged in the second relay box(which was already connected and running) and I plugged in the salinity module. I plugged the both relay boxes in and when the system came on, it would run for a second or two and shut off and come back on - over and over. Can anyone advise me on what to do?
Re: Expansion module
Did you use the +5VDC power supply that came with it?
It's required to get the HUB powered up.
Yep, both modules are plugged in and the red light is on.
Let's try this:
1. Connect just the hub into the relay box. Does it work?
2. Connect the relay expansion module into the hub, but leave the salinity out. Does it work?
3. Connect the salinity module into the hub. Does it work?
1. The hub worked
2. The relay expansion worked and the 2nd relay box seems to work fine.
3. Plugged in the salinity box and as soon as power is applied, the main relay box starts kicking in and out. I looked at the RA display while this is going on and the salt display is going wild.
Ah!!
We need to initialize the memory to accept the salinity module.
Can't remember if you have wifi. Do you?
I have the module but it is not hooked up yet...?
ok. so, let's do this.
1. Connect the usb cable to RA
2. Open Arduino
3. Open Serial Monitor on menu Tools->Serial Monitor
4. Make sure you have baud rate 57600
5. Type "GET \mi847,2550 " without the quote marks and make sure there is a space after 847
6. Does the controller respond with OK?
2. Open Arduino
nope, it does not respond at all
Let's go another route then.
Load this code
This should initialize the salinity calibration memory setting.
Load this code
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
#include <ReefAngel_EEPROM.h>
Phillips6610LCDInv e;
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.SalMax_write(2550);
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, "Done");
it says color white was not declared in this scope. remember I have the custom screen running.
Ok, so try this instead then:
e.lcd_init();
e.lcd_clear(255,0,0,132,132);
e.lcd_draw_text(0, 255, 10, 10, "Done");
That seemed to work. I had to disable my custom menu and then load your code. I then reloaded my pde. I hooked up the salinity module and the system is still running and not kicking in and out.
Now...what about calibration of the module and probe? Right now it says 51.2. I assume that is PPT?
Cool
Yes, ppt.
The calibration on the libraries you are running is broken
I fixed it for the new update.
So, we will need to load another code to calibrate the probe too.
Try this one:
Yes, ppt.
Try this one:
unsigned long avgSal=0;
e.lcd_init();
for (int a=0;a<6;a++)
avgSal+=SalRead();
avgSal/=5;
InternalMemory.SalMax_write(avgSal);
int SalRead()
int iSal=0;
Wire.requestFrom(I2CSalinity, 2);
if (Wire.available())
iSal = Wire.receive();
iSal = iSal<<8;
iSal += Wire.receive();
return iSal;
Just so I know what to expect..... what will this do? How will it work?
Looks like it will start up and then read the salinity and average the values and store in Internal Memory. Once it's finished, it will show "Done". Then you can reload your PDE and be all set for your salinity.
Well, it ran fast and said done before I could blink. I reloaded my pde and now it says - 5.9. That seems like an odd number. Does it seem right to you?
No doesn't seem right.
Let's see what the module is actually reporting.
We can manually set it later.
e.lcd_init();
e.lcd_draw_text(0, 255, 10, 10, SalRead());
int SalRead()
int iSal=0;
iSal = iSal<<8;
return iSal;
it does not like this line:
it flagged it yellow and gave an error that said:
invalid conversion int to char
Let's see if I got it right this time:
e.lcd_init();
char buff[10];
itoa(SalRead(),buff,10);
e.lcd_draw_text(0, 255, 10, 10, buff);
int SalRead()
int iSal=0;
iSal = iSal<<8;
return iSal;
I uploaded it and on the RA screen it says 0(zero)
LOL....yeah I do...thats funny. And I checked it to make sure it it hooked up - it is. and the power is on to the module as well.
on the module itself, there is a green light and a yellow light on
Ok, I hope I get this right this time....
#include <ReefAngel_Wifi.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Salinity.h>
ReefAngel.Init();
SetupCalibrateSalinity();
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW*5, "Done");
#if defined WDT || defined WDT_FORCE
wdt_reset();
#endif // defined WDT || defined WDT_FORCE
void SetupCalibrateSalinity()
bool bOKSel = false;
bool bSave = false;
bool bDone = false;
bool bDrawButtons = true;
unsigned int iS = 0;
byte offset = 65;
// draw labels
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, "Calibrate Salinity");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW*5, "35 PPT");
do
wdt_reset();
iS=0;
for (int a=0;a<15;a++)
iS += ReefAngel.Salinity.Read();
iS/=15;
ReefAngel.LCD.DrawCalibrate(iS, MENU_START_COL + offset, MENU_START_ROW*5);
if ( bDrawButtons )
if ( bOKSel )
ReefAngel.LCD.DrawOK(true);
ReefAngel.LCD.DrawCancel(false);
ReefAngel.LCD.DrawOK(false);
ReefAngel.LCD.DrawCancel(true);
bDrawButtons = false;
if ( ReefAngel.Joystick.IsUp() || ReefAngel.Joystick.IsDown() || ReefAngel.Joystick.IsRight() || ReefAngel.Joystick.IsLeft() )
// toggle the selection
bOKSel = !bOKSel;
if ( ReefAngel.Joystick.IsButtonPressed() )
bDone = true;
if ( bOKSel )
bSave = true;
while ( ! bDone );
if ( bSave )
// save PHMin & PHMax to memory
InternalMemory.SalMax_write(iS);
ReefAngel.SalMax = iS;
now I have a calibration screen. What is the correct way to use it ?
Does it show something other than 0?
Just place the probe in 35ppt or your tank, assuming it is correct and press OK
and it say on the screen:
35 ppt 3957
35 ppt 3957
