Changing the dimming port signal
bkc6868
Post by bkc6868 »
I have the RA star. Do I have to open the head unit to change the Jumpers? I need 0-5 own.
Re: Changing the dimming port signal
Yes
bkc6868
Post by bkc6868 »
bkc6868
Post by bkc6868 »
I see analog printed on board along with the channels but nothing about pwm and I don't see any jumper pieces
0-5V is right on the left side of where you saw analog.
bkc6868
Post by bkc6868 »
I saw that.. But the is no Jumpers
You are correct. They are not populated.
Not everyone changes signal types and you are the first one that mentioned it.
I'll instruct my contract manufacturer to install them on my next build.
You can get them on any electronic store or pull them from old motherboards.
bkc6868
Post by bkc6868 »
So should I jump every one of the 0-5v pins for pwm 0-5 volts?
Yeap.
bkc6868
Post by bkc6868 »
Something happened and I'm no longer getting 5 volts from pins 1&2 and 5&6. 3&4 and 7&8 still work fine. I've checked and rechecked the Jumpers and settings on everything.
There are only 4 channels and not 8. Which channels are you talking about?
bkc6868
Post by bkc6868 »
Daylight 1 and actinic 1 the #2 channels are working still
Do you have a multimeter?
bkc6868
Post by bkc6868 »
Yes that's how I know they aren't putting out the 5 volts but the others are
I'm assuming that the screen is showing 100% on those dimming channels on the RA* screen, right?
If so, The channels may have gotten damaged.
Can you check the voltages on these pads?
Actinic Channel
Daylight Channel
bkc6868
Post by bkc6868 »
Yes I can later when I get home
