I have an RA+ which has been running the same code for about a year with a single expansion, the 16 channel dimmer.
I am now hooking up a used expansion hub and connecting my dimmer expansion, a used relay expansion box, and the ph expansion.
If I just reboot the RA+ I figured I would not need to load new code to the RA+ and I would at least see the extra outlets and probe in the portal, but that isn’t happening.
Is that how it should work or do I have to include statements in my code and recompile and load it in order to get it to see the new probe and relay box?
Adding relay expansion and ph expansion
Re: Adding relay expansion and ph expansion
You need to upload a new code and enable the expansion modules you are connecting.
AlanM
OK. Just refer to them in a code statement to get those included or specifically include at the top somehow?
AlanM
Nevermind. I hadn't worked in the code in so long I forgot where to look for things.
It's ReefAngel.AddPHExpansion(); right?
Anything special in setup() to add the relay expansion? I didn't see that one in ReefAngel.h
AlanM
Nevermind again, heh. I saw it get recognized as a module in the Arduino GUI and it all compiled so I think I'm good.
I've been gone so long I hadn't seen that you released the Star. Nice. Gotta get me one at some point.
