Hey guys,
I just updated to 8.5.19 and it's saying my sketch is too big. The ONLY thing enabled at this point is wifi and watchdog timer. I used to have wifi, timer, led pwm and custom main enabled prior to the update.
i mainly updated so i can use the delayedon feature.
size is 33570 of 32256. Have any of you guys run into this? Thanks.
Jem
Libs 0.8.5.19 sketch too big
Re: Libs 0.8.5.19 sketch too big
Use the simple menu.
Add this to the features file:
#define SIMPLE_MENU
aranax
here's my sketch.
// Autogenerated file by RAGen (v1.0.4.92), (06/03/2011 19:28)
// RA_060311_1928.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
//static byte cloudchance=255;
//static byte cloudduration=0;
//static int cloudstart=0;
//static byte numclouds=0;
//static byte lightningchance=0;
//static byte cloudindex=0;
//static byte lightningstatus=0;
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//byte cloudchance=0;
//byte cloudduration=0;
//int cloudstart=0;
//End of PWM Expansion Code Header
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/wdt.h>
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15, 10, "T1:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, T1TempColor, 15+18, 10, 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 15, 10+10, "T2:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, 15+18, 10+10, 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 15, 10+20, "T3:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, 15+18, 10+20, 10);
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+60, 10, "PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, 15+78, 10, 100);
//ATO status
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15+60, 10+20, "Pump:");
byte highcolor;
char highstatus[10];
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+90, 10+20, "ON ");
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15+90, 10+20, "OFF");
//End ATO status
ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
//ReefAngel.LCD.DrawOutletBox(12, 35, TempRelay);
ReefAngel.LCD.DrawText(0,255,15,52,"RB:");
ReefAngel.LCD.DrawText(0,255,15,62,"BB:");
ReefAngel.LCD.DrawText(0,255,15,72,"CW:");
ReefAngel.LCD.DrawText(0,255,15,82,"WW:");
ReefAngel.LCD.DrawText(0,255,15+20,52,PWMChannel[LEDPWM0]);
ReefAngel.LCD.DrawText(0,255,15+20,62,PWMChannel[LEDPWM1]);
ReefAngel.LCD.DrawText(0,255,15+20,72,PWMChannel[LEDPWM2]);
ReefAngel.LCD.DrawText(0,255,15+20,82,PWMChannel[LEDPWM3]);
wdt_enable(WDTO_1S);
//randomSeed(analogRead(0));
//ReefAngel.Timer[1].SetInterval(random(15,35));
//ReefAngel.Timer[1].Start();
//ReefAngel.Timer[2].SetInterval(random(15,35));
//ReefAngel.Timer[2].Start();
// to force a specific time to the controller uncoment the 3 lines below
// It uses unix time: http://www.onlineconversion.com/unix_time.htm
//setTime(1373223660); // Unix time
// now();
// ReefAngel.RTC.set(now());
// Ports
// 1 Pump
// 2 Empty
// 3 Heater 1
// 4 Heater 2
// 5 Wavemaker 1
// 6 Wavemaker 2
// 7 Fan 1
// 8 Fan 2
// Using Std Lights and MH as Fan control by time
// Need a way to use PWM for fan control based on slope of PWM expansion
// Port 7
//InternalMemory.StdLightsOnHour_write(12);
//InternalMemory.StdLightsOnMinute_write(0);
//InternalMemory.StdLightsOffHour_write(19);
//InternalMemory.StdLightsOffMinute_write(0);
// Port 8
//InternalMemory.MHOnHour_write(12);
//InternalMemory.MHOnMinute_write(0);
//InternalMemory.MHOffHour_write(19);
//InternalMemory.MHOffMinute_write(0);
//InternalMemory.MHDelay_write(0);
//InternalMemory.HeaterTempOn_write(785);
//InternalMemory.HeaterTempOff_write(801);
ReefAngel.WaterChangePorts = B11111111;
ReefAngel.FeedingModePorts = B00110001;
ReefAngel.OverheatShutoffPorts = B00001100;
ReefAngel.LightsOnPorts = B11000000;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
//ReefAngel.Relay.On(Port5);
wdt_reset();
// Specific functions
//ReefAngel.StandardHeater(Port4);
ReefAngel.Relay.DelayedOn(Port5,1);
//ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardLights(Port4);
ReefAngel.MHLights(Port8);
ReefAngel.Relay.DelayedOn(Port1,1);
ReefAngel.Relay.Off(Port1);
// Alternating wavemaker (6 hours)
//if (((NumMins(hour(),minute()) >= NumMins(6,00)) && (NumMins(hour(),minute()) <= NumMins(9,05))) || (NumMins(hour(),minute()) >= NumMins(12,05)) && (NumMins(hour(),minute()) <= NumMins(15,00))) ReefAngel.Relay.On(Port5);
//else ReefAngel.Relay.Off(Port5);
//skimmer
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.On(Port5);
//refugium
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.On(Port7);
else ReefAngel.Relay.Off(Port7);
//if ( (hour() >= 18) || (hour() <= 14) ) // from 8p - 6a
// ReefAngel.Relay.Off(Port6);
//else
// during the day
// if ( ReefAngel.Timer[1].IsTriggered() )
// ReefAngel.Timer[1].SetInterval(random(10,150));
// ReefAngel.Timer[1].Start();
// ReefAngel.Relay.Toggle(Port6);
// ReefAngel.Relay.Toggle(Port5);
// ReefAngel.Relay.Off(Port5);
//else
// during the day
// if ( ReefAngel.Timer[2].IsTriggered() )
// ReefAngel.Timer[2].SetInterval(random(10,150));
// ReefAngel.Timer[2].Start();
//Start of PWM Expansion Code for Slope
// The 2 line above is what calculates the slope.
// You can change the schedule by changing the parameter inside the parenthesis of the PWMSlope() function
// The are as follow:
// 1st parameter: hour to start slope
// 2nd parameter: minute to start slope
// 3rd parameter: hour to end slope
// 4th parameter: minute to end slope
// 5th parameter: % of the PWM signal to start slope
// 6th parameter: % of the PWM signal to end slope
// 7th parameter: duration of slope in minutes
// 8th parameter: always the same as the variable before the PWMSlope() call
PWMChannel[LEDPWM0]=PWMSlope(12,30,22,00,0,80,240,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(12,00,22,15,0,70,240,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMSlope(13,30,21,30,0,55,180,PWMChannel[LEDPWM2]);
PWMChannel[LEDPWM3]=PWMSlope(13,0,20,00,0,0,180,PWMChannel[LEDPWM3]);
CheckCloud();
PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//ReefAngel.LCD.DrawText(0,255,5,120,PWMChannel[LEDPWM0]);
//ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
//ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
//ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(13 ,30)
#define Lightning_Change_per_Cloud 60
#define Actinic_Channels B000001
#define Daylight_Channels B001110
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
for (int a=0;a<6;a++)
PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
for (int b=0;b<6;b++)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
//ReefAngel.LCD.Clear(255,0,120,132,132);
//ReefAngel.LCD.DrawText(0,255,5,120,"C");
//ReefAngel.LCD.DrawText(0,255,11,120,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,120,"L");
//ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
ReefAngel.LCD.Clear(255,0,50,93,90);
ReefAngel.LCD.DrawText(0,255,15+60,52,"CD:");
ReefAngel.LCD.DrawText(0,255,15+60,62,"NC:");
ReefAngel.LCD.DrawText(0,255,15+80,62,cloudindex);
ReefAngel.LCD.DrawText(0,255,24+80,62,"of");
ReefAngel.LCD.DrawText(0,255,38+80,62,numclouds);
ReefAngel.LCD.DrawText(0,255,15+60,72,"CS:");
ReefAngel.LCD.DrawText(0,255,15+80,72,"00:00");
ReefAngel.LCD.DrawText(0,255,15+60,82,"LS:");
ReefAngel.LCD.DrawText(0,255,15+80,82,"00:00");
//int y=0;
//if ((cloudstart/60)>=10) y=11; else y=17;
//ReefAngel.LCD.DrawText(0,255,y,120,(cloudstart/60));
//if ((cloudstart%60)>=10) y=29; else y=35;
//ReefAngel.LCD.DrawText(0,255,y,120,(cloudstart%60));
int x=0;
if ((cloudstart/60)>=10) x=95; else x=98;
ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart/60));
if ((cloudstart%60)>=10) x=113; else x=119;
ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart%60));
//ReefAngel.LCD.DrawText(0,255,35,120,cloudstart);
ReefAngel.LCD.DrawText(0,255,15+80,52,cloudduration);
//ReefAngel.LCD.DrawText(0,255,110,120,PWMChannel[LEDPWM1]);
if (lightningchance)
//int y=0;
//if (((cloudstart+(cloudduration/2))/60)>=10) y=51; else y=57;
//ReefAngel.LCD.DrawText(0,255,y,120,((cloudstart+(cloudduration/2))/60));
//if (((cloudstart+(cloudduration/2))%60)>=10) y=69; else y=75;
//ReefAngel.LCD.DrawText(0,255,y,120,((cloudstart+(cloudduration/2))%60));
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95; else x=58;
ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113; else x=119;
ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))%60));
