New IDE 1.8.6
PostPosted: Mon Apr 23, 2018 11:32 am
I compiled the latest IDE 1.8.6 to test.
It will no longer have any of the tools (Restore preloaded, Wizard and Livraries Version).
Let me know if they work for you.
You will need the latest dev branch of the libraries: https://github.com/reefangel/Libraries/tree/dev
MacOSX: https://www.dropbox.com/s/jb6mstmkx5ijd ... o.zip?dl=0
Windows: https://www.dropbox.com/sh/vwvpxe1xpl7a ... B3nAa?dl=0
PostPosted: Mon Apr 23, 2018 6:52 pm
on macOS
  • the boards are not populated and only show the default arduino boards
  • the softwareserial included library is showing the __vect9 duplicate error, which needs this commented out in the file:
    //// Commented out for ReefAngel 1.8.5 compilation - conflicts with libraries
    //#if defined(PCINT0_vect)
    //ISR(PCINT0_vect)
    //  SoftwareSerial::handle_interrupt();
    //#endif
PostPosted: Mon Apr 23, 2018 10:23 pm
I updated the file.
Can you try again?
PostPosted: Tue Apr 24, 2018 3:13 am
Can you also do an arm build?
PostPosted: Tue Apr 24, 2018 3:35 am
Tried it just now and it's still doing the same. No ReefAngel boards are displaying and I'm still getting the SoftwareSerial error.
(I'm using the macOS version)
edit: it didn't appear as if the file was changed, so maybe it wasn't updated on Dropbox?
PostPosted: Tue Apr 24, 2018 4:45 am
akkord64 wrote:Can you also do an arm build?
I don't think the arduino app compiles on arm or has a build script created for arm.
PostPosted: Tue Apr 24, 2018 6:46 am
It actually does support ARM. Official IDE is downloadable and its a simple build.xml modification to include the arm platform for compile.
https://crimier.wordpress.com/2015/06/1 ... pberry-pi/
I was working on a parallel compile process as your other Sierra thread was progressing, but then Roberto released this thread for testing.
I am looking to hang a RPI off the RA FTDI cable and keep a pristine Arduino IDE+Library dev environment where I can access via vnc for remote uploading.
PostPosted: Tue Apr 24, 2018 8:24 am
I don't remember where I put my pi, but I'll push the changes to github and you should be able to compile it easily.
PostPosted: Tue Apr 24, 2018 10:04 am
It's been pushed
PostPosted: Tue Apr 24, 2018 11:27 am
akkord64 wrote:It actually does support ARM. Official IDE is downloadable and its a simple build.xml modification to include the arm platform for compile.
good to know.
some of the issues roberto hit with this build, i encountered on mine. i got mine compiling but it was not generating the output of the features included and i didn’t have a way to test the builds as all of my devices are at work.
Next
