led dimming to led on/off ports
Ask in here.
PostPosted: Fri May 18, 2018 6:30 pm
i want to add update led code i tryed my self from code from lnevo but it dont do anything i moved controller to my moms tank so none of my old code works with this when i remove parts i dont want
what do i need to add/remove to have port 3 turn on when dimming add-on channel 0 is grater then 0% and and off if at 0%
what do i need to add/remove to have port 4 turn on when dimming add-on channel 1 is grater then 0% and and off if at 0%
        #define Mem_B_AtoHourInterval     101
void init_memory() {
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //mb101
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.SingleATO(true, Port1 , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
    ReefAngel.StandardLights( Port3,9,0,19,0 );
    ReefAngel.StandardLights( Port4,9,0,19,0 );
    ReefAngel.StandardHeater( Port5,775,785 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,65,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,45,0) );
    ReefAngel.DCPump.SetMode( NutrientTransport,70,10 );
    ReefAngel.DCPump.ExpansionChannel[4] = Sync;
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
    ReefAngel.Portal( "troylong45" );
PostPosted: Sun May 20, 2018 12:25 pm
troylong45 wrote:what do i need to add/remove to have port 3 turn on when dimming add-on channel 0 is grater then 0% and and off if at 0%
This should work for the standard PWM expansion device (with 6 channels)
You would need something like this inside your loop() section:
if (ReefAngel.PWM.GetChannelValue(0) > 0) {
   // Value over 0%
   ReefAngel.Relay.On(Port3);
} else {
   // otherwise, value IS 0 or less (which should never happen)
   ReefAngel.Relay.Off(Port3);
troylong45 wrote:what do i need to add/remove to have port 4 turn on when dimming add-on channel 1 is grater then 0% and and off if at 0%
And for this one...
if (ReefAngel.PWM.GetChannelValue(1) > 0) {
   // Value over 0%
   ReefAngel.Relay.On(Port4);
} else {
   ReefAngel.Relay.Off(Port4);
Then, I would also remove these lines too:
Because they will override the port status from the PWM channels.
So, your loop section would look like this:
   // Value over 0%
} else {
   // Value over 0%
} else {
PostPosted: Wed May 23, 2018 9:29 am
Thanks ill try that i think the code I was trying was missing some of These symbols }{ or actually I think there was a { be for the "if" command. That might be why so it never was reading the if or maybe else reading , cus it would force the lights on no matter % or relay overuse setting I would set
Ill be back if i get no where
Is there a code for dummies section like what call outs are and mean and commands
PostPosted: Wed May 23, 2018 7:23 pm
There's not really a section or manual that spells out what all the functions are and how to use them or what they mean. The data is scattered throughout the forum and it ultimately lies inside the libraries. I think there was an effort to do this a while back but I do not know off hand if anything was finished or worked on.
PostPosted: Sat May 26, 2018 3:18 pm
it worked great thanks
libraries would help me understand more on my own?
PostPosted: Sun May 27, 2018 6:17 am
troylong45 wrote:it worked great thanks
yes, looking at the libraries will (or should) help you understand better. if you can understand the code and how things function, it could benefit you.
PostPosted: Sun May 27, 2018 12:35 pm
get the if ,else deal .
Like what maybe "if(X LOCATION(X VALUE) = X VALUE"
it is looking for the location to be = to value
And will make "{X LOCATION (X COMMAND) ; }else{X LOCATION (X COMMAND) ; }
So maybe
if (reefangel.pwm.daylights) = 50 { reefangle.relay.on(port6) ; }else{reefangle.relay.off(port6) ; }
If spelled correct+correct location and capitalized correctly then that make
Relay box main port 6 on only if daylights is 50% and off if not
PostPosted: Sun May 27, 2018 6:00 pm
yeah, you got the right idea (and yes, if you use proper capitalization and formatting)
PostPosted: Sun May 27, 2018 9:48 pm
Then the rest is just kinda math and calling out What's already been created.
I realize there is way more behind the scenes when I opened lib. On dropbox Lol
Is the wave pattern topic up todate I was trying to find that info on drop box but must have missed it I wanna try to take a crack at adapting the dcpump mode to my liking and pumps and to find sync and antisync off sets (plus or minus value)
PostPosted: Mon May 28, 2018 10:13 am
troylong45 wrote:Then the rest is just kinda math and calling out What's already been created.
yes, that topic is up-to-date, however there is some additional information that is in a post towards the end of the thread. not sure how critical it is but I'm pretty sure it is important (something like saying the wave forms are built in the libraries or something like that). just make sure you read through the entire thread and not just the first post.
one thing to note is that you may have to experiment with the settings and modes. I have some gyres that won't do some of the modes and I found out during testing.
Return to How do I code ...
