i ordered 3 new temp probes, 2 short and 1 long. I need the long probe to reach into the display and control the temp.
The problem is that the probes are ordered by the manufacture. So no matter where inserted the shorter probe always defaults to the main probe. Is there a way to default the longer probe to be the main and control my display temp?
Temperature Probe T1 T2 T3
Re: Temperature Probe T1 T2 T3
Just use the wizard and pick the temp probe you want to use for your heater.
It should be something like this:
