Odd compile error
jcjrogersstar
Odd compile error
Post by jcjrogersstar »
I'm getting the following error when I compile:
Warning: strpos(): Empty needle in D:\webwizard\compile.php on line 349
Notice: Undefined offset: 1 in D:\webwizard\compile.php on line 350
Progress: 100.00%
Your code was compiled sucessfully.
What is weird is that I can compile the exact same code with no errors, copy/paste the code into a new file, and then when I compile, I get the errors. Another odd thing is that I don't have anywhere near 349 lines of code. This is the code:
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    ReefAngel.Star();
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
    ReefAngel.AddRANet();  // RANet Add-On Module
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.FeedingModePortsE[1] = Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[1] = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[1] = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.LightsOnPortsE[1] = Port1Bit | Port2Bit;
    InternalMemory.OverheatTemp_read();  // trying this code to see if it pulls internal memory overheat temp.
    ReefAngel.Relay.On( Box2_Port4 );
    ReefAngel.StandardLights( Box1_Port1 ); //Main LEDs
    ReefAngel.StandardLights( Box2_Port2 ); //Light fans
    ReefAngel.StandardHeater2( Box1_Port2 );
    ReefAngel.Relay.Set( Box2_Port3, !ReefAngel.Relay.Status( Box2_Port2 ) ); //Refugium LED runs opposite of Light fans
    ReefAngel.StandardHeater2( Box2_Port5 );
    ReefAngel.StandardFan2( Box2_Port6 );  //Sump Fans
    //ReefAngel.CO2Control( Box1_Port6 );  //relay empty right now
    ReefAngel.Relay.DelayedOn( Box2_Port7 ); //Skimmer
    ReefAngel.WaterLevelATO( 1,Box2_Port8); //Sump ATO
    //ReefAngel.PWM.DaylightPWMSlope(); - not using PWM for main LEDs
    //ReefAngel.PWM.ActinicPWMSlope(); - not using PWM for main LEDs
    ReefAngel.StandardHeater(Box1_Port7,788,793); //Manages UV bulb on/off based on tank temp.
   boolean buzzer=false;
   // if ( ReefAngel.isATOTimeOut() ) buzzer=true;
   if ( ReefAngel.isOverheat() ) buzzer=true;
   if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
   if ( ReefAngel.Params.PH > 840 ) ReefAngel.Relay.Off( Box2_Port8 );
    MyOwnStandardLights(Box2_Port1,-InternalMemory.ActinicOffset_read());  // Calls my new offset to allow negative offset for T5s.
    ReefAngel.Network.Cloud();
    ReefAngel.ShowTouchInterface();
    /// Code from Roberto to create a new callout for T5s to allow setting parameters in Internal Memory.
    void MyOwnStandardLights(byte Relay, int MinuteOffset)
   int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-MinuteOffset;
   int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+MinuteOffset;
   ReefAngel.StandardLights(Relay,
         onTime/60,
         onTime%60,
         offTime/60,
         offTime%60
// RA_STRING1=U2FsdGVkX1+BrIhUnNJiKHbFL6wohK41+33EQ2nHfFo=
// RA_STRING2=U2FsdGVkX1+EmuJjuPrMWBEHac9zWSjiW8ZytHk/q+M=
// RA_STRING3=Chloe's House-2.4
// RA_LABEL LABEL_ACTINIC=Actinic
// RA_LABEL LABEL_DAYLIGHT=Daylight
// RA_LABEL LABEL_PORT11=Main LEDs
// RA_LABEL LABEL_PORT12=Heater 2
// RA_LABEL LABEL_PORT13=Gyre Pumps
// RA_LABEL LABEL_PORT14=Kalk Stirrer
// RA_LABEL LABEL_PORT15=Salt Mix Tank
// RA_LABEL LABEL_PORT16=Co2 Control
// RA_LABEL LABEL_PORT17=Unused
// RA_LABEL LABEL_PORT18=Unused
// RA_LABEL LABEL_PORT21=Main T5s
// RA_LABEL LABEL_PORT22=Light Fans
// RA_LABEL LABEL_PORT23=Refugium LED
// RA_LABEL LABEL_PORT24=Return Pump
// RA_LABEL LABEL_PORT25=Heater 1
// RA_LABEL LABEL_PORT26=Sump Fans
// RA_LABEL LABEL_PORT27=Skimmer
// RA_LABEL LABEL_PORT28=ATO Pump
Is this an issue?
Re: Odd compile error
I made a few changes to the webwizard,
Can you try again?
jcjrogersstar
Just getting a chance to get back to this. When I did a standalone compile, no errors. However, when I uploaded, the compile portion gave me these errors:
Compiling code for RA_STAR board
Number of Relay Expansion Modules: 2
Dimming Signal
Reef Angel Star
Multi Channel Water Level Expansion Module
RANet framework
Warning: strpos(): Empty needle in D:\webwizard\compile.php on line 351
Notice: Undefined offset: 1 in D:\webwizard\compile.php on line 352
Progress: 100.00%
Remote upload firmware is ready.
Your Reef Angel Star should download and start the new firmware next time it connects to the server.
This process may take up to 5 minutes.
My bad.
I fixed upload too.
Try it again.
