Power Control Expansion
PostPosted: Fri Jun 29, 2018 4:33 pm
OK, I can't figure out how to get this installed. I've got an expansion hub with a second relay box and salinity expansion. I've set the power control expansion to a unique ID and connected to the expansion hub. There is power to the power control expansion.
The power control expansion does not show up as a new box on the head unit, but does show up on the portal. However, it does not respond to the portal. It is always off.
Any ideas.
PostPosted: Fri Jun 29, 2018 4:36 pm
Correction. It does not show up on the portal, forgot that I unplugged the wireless.
When I first installed the power control expansion, it did show up, but was always ON. I thought maybe it was the ID, so I changed, but now stays OFF even when I go back to the original ID.
PostPosted: Fri Jun 29, 2018 8:44 pm
Did you set the power control as id 2?
Your expansion relay box is 1 and the power control should be 2.
Just to confirm, run the i2cscanner code. I'm on my cell, but if you search, you will find.
PostPosted: Sat Jun 30, 2018 9:27 am
Set PCE to ID 2. It doesn't seem to be recognizing it at all - nothing on the head unit menu.
Here is I2CScanner.
ÿ
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1          addr: 2          addr: 3          addr: 4
addr: 5          addr: 6          addr: 7          addr: 8
addr: 9          addr: A          addr: B          addr: C
addr: D          addr: E          addr: F          addr: 10
addr: 11          addr: 12          addr: 13          addr: 14
addr: 15          addr: 16          addr: 17          addr: 18
addr: 19          addr: 1A          addr: 1B          addr: 1C
addr: 1D          addr: 1E          addr: 1F          addr: 20 found!
addr: 21          addr: 22          addr: 23          addr: 24
addr: 25          addr: 26          addr: 27          addr: 28
addr: 29          addr: 2A          addr: 2B          addr: 2C
addr: 2D          addr: 2E          addr: 2F          addr: 30
addr: 31          addr: 32          addr: 33          addr: 34
addr: 35          addr: 36          addr: 37          addr: 38 found!
addr: 39          addr: 3A          addr: 3B          addr: 3C found!
addr: 3D          addr: 3E          addr: 3F          addr: 40
addr: 41          addr: 42          addr: 43          addr: 44
addr: 45          addr: 46          addr: 47          addr: 48
addr: 49          addr: 4A          addr: 4B          addr: 4C
addr: 4D found!   addr: 4E          addr: 4F          addr: 50 found!
addr: 51          addr: 52          addr: 53          addr: 54 found!
addr: 55          addr: 56          addr: 57          addr: 58
addr: 59          addr: 5A          addr: 5B          addr: 5C
addr: 5D          addr: 5E          addr: 5F          addr: 60
addr: 61          addr: 62          addr: 63          addr: 64
addr: 65          addr: 66          addr: 67          addr: 68 found!
addr: 69          addr: 6A          addr: 6B          addr: 6C
addr: 6D          addr: 6E          addr: 6F          addr: 70
addr: 71          addr: 72          addr: 73          addr: 74
addr: 75          addr: 76          addr: 77          addr: 78
addr: 79          addr: 7A          addr: 7B          addr: 7C
addr: 7D          addr: 7E          addr: 7F          addr: 80
PostPosted: Sat Jun 30, 2018 9:41 am
That is box5. 38 is box1 and 3c is box 5
PostPosted: Sat Jun 30, 2018 9:51 am
Here is a pic of the switches, isn't this 2?
PostPosted: Sun Jul 01, 2018 10:23 pm
You will need to try a different combination to find out.
It looks correct.
PostPosted: Mon Jul 02, 2018 4:06 am
Not sure I follow. Should I keep trying switch combinations until it registers as Box2? Which number is Box2?
PostPosted: Mon Jul 02, 2018 10:35 am
Yeah. Box2 is 0x39
PostPosted: Wed Jul 04, 2018 6:44 am
Found it, at least I think so. Still not working, doesn't show up on head unit...
I2CScanner ready!
addr: 39 found!   addr: 3A          addr: 3B          addr: 3C
Next
Return to Addons
