Creating custom modes in menu
tngo
Post by tngo »
Hi All,
Is there a way that I would be able to create a selectable custom mode similar to the feeding and water changing modes? If say I wanted to create a mode to fill my salt mixing bucket with ro/di water, which would turn on/off a certain relay after a set time. Being able to select it in the menu allows me to initiate the mode at any time.
Tim
Re: Creating custom modes in menu
You can use it like Lee did.
Just use a virtual relay port to trigger the mode.
Add a second or third relay box, even though you don't physically have it and use the relays on that port to trigger the mode.
tngo
Post by tngo »
Thanks Roberto. Found the virtual relay topic on the forums.
http://forum.reefangel.com/viewtopic.ph ... ort#p38635
Tim
