Errors when compiling with dev branch
Posted: Fri Nov 23, 2018 10:58 pm
by sbidny
I have tried pulling down the dev branch, and I am seeing the following compiler errors, which prevent me from even attempting an upload:
In file included from sketch_nov23a.cpp:31:
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:305: error: a brace-enclosed initializer is not allowed here before '{' token
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:368: error: ISO C++ forbids initialization of member 'ParamArrayByte'
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:368: error: making 'ParamArrayByte' static
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:368: error: invalid in-class initialization of static data member of non-integral type 'unsigned char* [94]'
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:370: error: a brace-enclosed initializer is not allowed here before '{' token
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:401: error: ISO C++ forbids initialization of member 'ParamArrayInt'
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:401: error: making 'ParamArrayInt' static
/Users/sbidny/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:401: error: invalid in-class initialization of static data member of non-integral type 'int* [19]'
Re: Reef Angel Web Wizard
Posted: Fri Nov 23, 2018 10:59 pm
Sorry, is this for the web wizard or you are trying to use the Arduino IDE?
Posted: Fri Nov 23, 2018 11:01 pm
by sbidny
The IDE. Trying to use cloud WiFi and upload using the Bluetooth adapter via the IDE.
Re: Errors when compiling with dev branch
Posted: Fri Nov 23, 2018 11:11 pm
You may need to use the new Arduino IDE.
I can't remember if the old one compiles dev branch.
http://forum.reefangel.com/viewtopic.php?f=7&t=6790
Posted: Fri Nov 23, 2018 11:13 pm
by sbidny
It seems you may have broken this out from the original thread. Not sure it’s going to make as much sense without the original context.
Some of us are trying to use cloud WiFi but still want to upload using the Bluetooth adapter. The web wizard doesn’t support the Bluetooth adapter. And the IDE doesn’t support cloud WiFi, due to older libraries.
Therefore, someone suggested we pull down the dev branch (which is what the web wizard is using for whatever reason) into the IDE and then use the Bluetooth adapter. That’s when I saw the compiler errors.
by sbidny
I’ll give that a shot...
Posted: Sat Nov 24, 2018 10:10 pm
by sbidny
And now, after using IDE 1.8.6, I'm getting...
/var/folders/3m/3bb43tld2fj36jzpj5p4ry780000gs/T//cc1YIvJ2.ltrans2.ltrans.o: In function `main':
cc1YIvJ2.ltrans2.o:(.text.startup+0xef4): undefined reference to `ReefAngelClass::CloudPortal()'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Reef Angel Plus Controller.
Posted: Sat Nov 24, 2018 10:17 pm
Are you sure you are using the dev branch and it is placed in the correct place?
https://github.com/reefangel/Libraries/archive/dev.zip
This path is very strange: /var/folders/3m/3bb43tld2fj36jzpj5p4ry780000gs/T//cc1YIvJ2.ltrans2.ltrans.o:
Looks like a linux machine.
Posted: Sat Nov 24, 2018 10:52 pm
by sbidny
OS X. I believe I am using the latest dev branch and have placed it in the correct location. Will try again.
Posted: Sun Nov 25, 2018 3:42 pm
by sbidny
No luck. If I remove the line ReefAngel.CloudPortal(); from the function void loop() it compiles.
Posted: Sun Nov 25, 2018 3:56 pm
Can you send me a screen shot of File->Preferences window of your Arduino IDE?
Posted: Sun Nov 25, 2018 9:41 pm
by sbidny
Posted: Sun Nov 25, 2018 10:36 pm
is the sketchbook location where you placed the dev branch?
Can you send me a screenshot of your folder structure?
Posted: Mon Nov 26, 2018 10:07 am
by sbidny
Yes, it’s the location where I put the dev libraries. Here’s the structure:
/Users/sbidny/Documents/Arduino 1.8.6/libraries/
I will grab a screenshot when I get a chance as well.
Posted: Mon Nov 26, 2018 10:21 am
by sbidny
It's definitely picking up the dev libraries, FWIW, since the call to ReefAngel.StandardHeater1() is working. The older libraries did not support this call. I believe they required ReefAngel.StandardHeater().
Posted: Mon Nov 26, 2018 10:27 am
by sbidny
Screenshot of folder structure:
Posted: Mon Nov 26, 2018 10:54 am
Light bulb turned on.
I think you are also missing the updated features file.
https://github.com/reefangel/FeaturesAndUpdateFiles
Update the files on your folder /Users/sbidny/Documents/Arduino 1.8.6/libraries/update
Posted: Mon Nov 26, 2018 11:26 am
by sbidny
That seemed to do it. I am now able to compile. Will try to upload using the Bluetooth adapter when I get home tonight. Thanks!
Posted: Mon Nov 26, 2018 7:19 pm
by sbidny
I was able to upload using the Bluetooth adapter. However, I am now seeing tons of trailing random characters on the display. Seems as if it’s using uninitialized character buffers for strings.
Could it be that the prior version automatically initialized allocated buffers and that the new version requires an explicit initialization?
Posted: Mon Nov 26, 2018 7:27 pm
Is it the plus or star board?
Posted: Mon Nov 26, 2018 7:31 pm
by sbidny
Plus
Posted: Mon Nov 26, 2018 10:05 pm
Can you post your code?
Posted: Sat Dec 01, 2018 10:12 pm
by sbidny
Just playing around right now, so there's not much to it. Basically, all it's doing is setting the 0-10v ports to 100%.
    ReefAngel.PWM.SetDaylight(100);
    ReefAngel.PWM.SetActinic(100);
    ReefAngel.Portal("sbidny");
    ReefAngel.DDNS("reef"); // Your DDNS is sbidny-reef.myreefangel.com
Posted: Mon Dec 03, 2018 9:38 am
by sbidny
FYI, when I upload the same (minus the ReefAngel.CloudPortal() call) via Arduino 1.0.1, I don't see the same issue with trailing characters.
I'll try uploading using 1.8.6 without the CloudPortal() call.
Posted: Mon Dec 03, 2018 6:46 pm
by sbidny
Same issue.
Posted: Mon Dec 03, 2018 7:00 pm
I wonder if this is a MacOSX issue only.
I'm not able to replicate.
lnevo, can you report if you have this issue?
Posted: Mon Dec 03, 2018 7:20 pm
by sbidny
I’ll try to get it going from Windows and see if the problem persists.
