New temp probe not working
Posted: Wed Apr 03, 2019 10:09 am
by alexr54
Recently got a new temp probe in and its not working at all.
My original is working fine, the new one is not giving any readings at all.
Did something change or is my new temp probe just faulty?
Re: New temp probe now working
Posted: Wed Apr 03, 2019 4:46 pm
Did you reboot after installing it? You could try it in a different port if any difference.
Also the temp probes have a digital serial number and the order the probes appear is determined by that. So the new one wont' necessary be T2...
You may also need to try one at a time. Either way, it isn't recognized without rebooting.
Posted: Thu Apr 04, 2019 10:20 am
by alexr54
lnevo wrote:Did you reboot after installing it? You could try it in a different port if any difference.
Yes i have tried all 3 ports and all after rebooting. I had a working temp probe in port 1 and 2, when removing the one in port 2 i accidentally ripped the wires so ordered a replacement temp probe. Its not working.
Posted: Thu Apr 04, 2019 10:30 am
Just to be sure, you have to connect the new probe and reboot. Not the other way around.
All probes are scanned only when the unit boots up. If it is indeed not working, send me a PM.
Posted: Thu Apr 04, 2019 11:35 am
by alexr54
rimai wrote:Just to be sure, you have to connect the new probe and reboot. Not the other way around.
Yup i have rebooted several times. I will try again just to be sure.
Posted: Thu Apr 04, 2019 12:45 pm
by alexr54
Yes its not working.
