Wifi keeps disconnecting
Posted: Thu Oct 24, 2019 4:39 pm
by alexr54
Are there any tips or tricks I can do to get the wifi attachment to be more stable?
It’s hit or miss when it comes to its connection.
I can connect and refresh 5x with no issues sometimes, then when I try to connect 3 minutes later it’s offline and can’t connect. It’s off and on like this all the time.
Connects fine sometimes. Other times it won’t be able to connect for hours.
I don’t touch anything, the connection gets established.
It’s just really strange behavior with the wifi attachment and completely unstable.
It does have the latest update. It’s set with a static IP and all my port forwarding rules are working.
It’s the same behavior if I am connecting locally or remotely.
Re: Wifi keeps disconnecting
Posted: Fri Oct 25, 2019 3:24 pm
by mav3rick478
Mine seems to work better with the case off. The cable plug makes better contact that way.
Sent from my Pixel XL using Tapatalk
Posted: Sat Oct 26, 2019 1:38 pm
Or you can add an external antenna too. Search the forums. Someone did it with good results.
A better solution is the cloud wifi attachment that maintains an always on connection to the cloud server and you don't need to keep making connections to the attachment itself.
Posted: Sat Nov 23, 2019 5:49 pm
by alexr54
For future reference here is the link I found about adding an antenna.
Sounds like a good idea. I’m doing it
http://forum.reefangel.com/viewtopic.ph ... al+antenna
Posted: Sat Nov 23, 2019 6:36 pm
by alexr54
I remember reading something at some point about changing the timeout setting on the wifi attachment. Its currently at the default of 200.
Is this something i should try?
Are there any other tweaks in the wifi settings that may help it stay connected at all times?
I am trying the xternal antenna, but in all honesty it does not seem like a connection strength issue. When i unplug the wifi attachment (when connection fails) and plug it right back in, it connects within seconds. I need to do this regularly.
Here is my current code on the wifi attachment:
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-7f
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.2.201:8080
NM=255.255.255.0
GW=192.168.2.1
HOST=re.mo.ve.d80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=8.8.8.8
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=re.mo.ve.d:21
File=wifly-GSX.img
User=roving
Pass=re.mo.ve.d
Dir=public
Timeout=200
FTP_mode=0x0
SSID=re.mo.ve.d
Chan=0
ExtAnt=1
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=re.mo.ve.d
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=re.mo.ve.d:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
Posted: Sun Nov 24, 2019 11:23 am
When it disconnects, does it blink blue?
Posted: Sun Nov 24, 2019 12:43 pm
by mav3rick478
That antenna is no longer in stock, can we use other ones listed that are I'm guessing are stronger?
@rimai when mine loses connection yes it's blinking blue.
Sent from my Pixel 4 XL using Tapatalk
Posted: Sun Nov 24, 2019 3:43 pm
by alexr54
I got this antenna and it is working fine
WiFi Antenna 8dBi Omni RP SMA Male RPSMA Antenna 2.4Ghz 5.8Ghz Dual Band + 20cm U.FL to RP-SMA Female Extension Cable for Mini PCIe Card Notebook PS4 Drone 1 Pcs
https://www.amazon.com/dp/B07QKD56TT/re ... 2DbPK5KF89
It did timeout once since I installed the antenna but a few minutes later it worked fine.
Next time it times out I’ll look to see what color is blinking.
Posted: Sun Nov 24, 2019 5:03 pm
by mav3rick478
alexr54 wrote:I got this antenna and it is working fine
Posted: Mon Nov 25, 2019 11:26 am
by alexr54
rimai wrote:When it disconnects, does it blink blue?
Yes it is blinking blue.
Posted: Wed Dec 11, 2019 1:34 pm
by alexr54
Its been much more reliable after adding the external antenna.
It does sometimes disconnect and blinks green and blue, but its much more stable.
