What are you all using for powerheads?
Posted: Thu Mar 05, 2020 7:13 pm
What is everyone controlling for powerheads? Need a pair for the 72 build.
https://forum.reefangel.com/
tngo wrote:Mainly Ecotech MP40s; I have 3 in my 180G. I have tried the Jebao, but they give out in about a year. I stopped replacing them after the third one failed. Hydors will start to get erratic and either stop working or begin to spin backwards sometimes after a year or two. They are cheap but not controllable. The Ecotechs I've had to replace one wetside so far after about 4 years. Ecotechs are pricey, but they are stable.
Tim
Problem I have with those and I own an ice cap 3k is finding one that will go low enoughrimai wrote:Have you thought about the gyre?
binder wrote:I have a pair of maxspect gyre xf230s running on my 75 gallon tank. I run them alternating at around 50-52%. works pretty good for me.
Sent from my Pixel 2 using Tapatalk
I've considered nthst, but still seem a bit bulky lookingGermanDude wrote:Tunze pumps. Rock solid and controllable.
Excellent tech support in the US.
I have 2 clams, a couple montipora plates, 4-5 sps colonies, a millipora, 6 different acan colonies, 2 large trumpet colonies, plus softies.SouthernReefer wrote:binder wrote:I have a pair of maxspect gyre xf230s running on my 75 gallon tank. I run them alternating at around 50-52%. works pretty good for me.
What types of coral are you keeping? I was considering a pair of the ice cap 1ks too but thought it would be too much flow.
binder wrote:I have 2 clams, a couple montipora plates, 4-5 sps colonies, a millipora, 6 different acan colonies, 2 large trumpet colonies, plus softies.SouthernReefer wrote:binder wrote:I have a pair of maxspect gyre xf230s running on my 75 gallon tank. I run them alternating at around 50-52%. works pretty good for me.
I'm attaching a FTS of my tank.
Beautiful tank! So it wouldn't be too much power? I'm after alot of the same things. Hammers, frogspawns clams acans lps, and choice sps like montis cap
Are you using the apex module to unlock the 0 to 10 control into reef angel?binder wrote:Thanks!
I have a hammer coral in it on the left side.
it honestly shouldn't be too much for it. you definitely want to have flow /circulation. you could probably get by with just one (i did for a while). the top part of the tank gets better flow than the bottom (for obvious reasons). I would keep the frogspawn / clams / etc away from the sides where the flow hits the glass and deflects down.
ultimately its your call but i personally think you will be fine using one. you can even run the pumps slower if you desired.
I use the icecap module for the apex and created a custom cable to interface with the Reef Angel.SouthernReefer wrote:Are you using the apex module to unlock the 0 to 10 control into reef angel?binder wrote:Thanks!
binder wrote:I use the icecap module for the apex and created a custom cable to interface with the Reef Angel.SouthernReefer wrote:Are you using the apex module to unlock the 0 to 10 control into reef angel?binder wrote:Thanks!
absolutely. easiest for the star. I can help guide you if you need it. the star uses a network cable. cut one end off and splice some of the wires together with a 2.5 mm mono cable. pretty straight forward. I bought a 6ft mono cable and got 2 - 3ft cables from it. then bought a distribution block to split the wires and make everything look clean and reduce the need to solder. (i don't like soldering thin cables...well working with them in general sucks). it was much harder for the plus because of the connector but still very doable.SouthernReefer wrote:binder wrote:I use the icecap module for the apex and created a custom cable to interface with the Reef Angel.SouthernReefer wrote: Are you using the apex module to unlock the 0 to 10 control into reef angel?
Fairly simple to build?
Good as I've got it on order. I'll be running 2 of the reef octopus octopulse 2s that's the only item I'm looking to use 0 to 10 v for. If I decide to add a new return pump with o 0 to 10 I'll have to build my own cable then.binder wrote:I believe so. The only downside, I think, is that it only uses 4 of the 8 wires. This will allow you to only use 2 of the 4 channels. it's not a big deal initially, unless you plan to use all 4 of the pwm channels.
you will have to look at what wires are used in the network connector to tell what pwm channels are being used. I have that same cable but not handy, so I can't tell you. the best way is to plug both cables in and have the pwm set to zero. then manually change 1 channel at a time and see what happens. (of course, you probably already knew that but I still felt like sharing)SouthernReefer wrote:Good as I've got it on order. I'll be running 2 of the reef octopus octopulse 2s that's the only item I'm looking to use 0 to 10 v for. If I decide to add a new return pump with o 0 to 10 I'll have to build my own cable then.binder wrote:I believe so. The only downside, I think, is that it only uses 4 of the 8 wires. This will allow you to only use 2 of the 4 channels. it's not a big deal initially, unless you plan to use all 4 of the pwm channels.
anytime. feel free to ask all questions you want or even PM me. I'll help as best as I can.SouthernReefer wrote:Actually I didn't. This is my first controller and first time with 0 to 10 control, but I'm a tech guy so very inclined, but still would of taken a bit of research, so that saves me some time. I appreciate it!!
