RA Star Port Labels
RA Star Port Labels
Is there a way to change the labels on these?
Re: RA Star Port Labels
Are you using the web wizard or Arduino IDE?
cosmith2
Post by cosmith2 »
Wizard. I can use the IDE if need be.
It seems like there was a function on the RA+ to assign labels on the screen. It's been a while and I can't remember. :mrgreen:
cosmith2
Post by cosmith2 »
ReefAngel.CustomLabels is the function on the Plus. Is there an equivalent on the Star?
On the webwizard, add these lines at the end of your code:
// RA_LABEL LABEL_TEMP1=Room
// RA_LABEL LABEL_TEMP2=Display
// RA_LABEL LABEL_ATOLOW=ATO
// RA_LABEL LABEL_ATOHIGH=Skimmate
// RA_LABEL LABEL_ACTINIC=Gyre 1
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT=Daylight
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=ATS Pump
// RA_LABEL LABEL_PORT12=ATO
// RA_LABEL LABEL_PORT13=Fan
// RA_LABEL LABEL_PORT14=ATS Light
// RA_LABEL LABEL_PORT15=Gyre
// RA_LABEL LABEL_PORT16=Heater
// RA_LABEL LABEL_PORT17=Skimmer
// RA_LABEL LABEL_PORT18=Return
Got it. Thanks!
I also found out the Wizard can do it, if I'd bother to enter in the labels. :D
What about using the IDE? Is it inside RA_CustomLabels.h ?
You can change the file RA_CustomLabels.h
rimai wrote:You can change the file RA_CustomLabels.h
awesome thanks! that's what I thought (I discovered it after I posted my question).
