Email Notifications not listed
Hi, hoping someone can please explain why my email notifications are not listed where I normally see them (see attached screenshot). I was getting notifications and when I went to adjust the temp and ph range, I noticed they were missing so I added them again and again and again... now I get several notifications at the same time. how do I see them? and delete all the duplicates?
thanks
thanks
- Screen Shot 2020-03-27 at 12.28.14 PM.png (129.13 KiB) Viewed 6185 times
Re: Email Notifications not listed
There is a bug on the backend that if you use a comma in the description of the alert, it will generate an error and anything after that will not show. I deleted the ones with the comma. They should all be appearing now.
Excellent! thanks Roberto
Roberto, this must have happened to me as well. All of my notifications appear to be gone. Please fix.
I can see them.
Are you sure they are not there?
I can even see that some of them got triggered today.
Still not there.rimai wrote:I can see them.
- ra_portal.png (162.17 KiB) Viewed 5996 times
Fixed. Thanks!
I don't know what I'm doing in the portal, but every time I add a trigger based on pH values, I lose everything. Please fix and let me know what to avoid to keep this from happening (I don't think I had a comma).
There is a bug on the backend that if you use the following, you have problems: , < > " and '
Only in the "description", right? You can use in the trigger (the name), correct?rimai wrote:There is a bug on the backend that if you use the following, you have problems: , < > " and '
Got it. Thanks.rimai wrote:I think on both.
