Page 1 of 4
Uapp Graph shows no Data to display always.
Posted: Mon Oct 26, 2020 7:32 am
by SouthernReefer
How do i get Uapp to actually graph for me? Now that the tanks been up and cycling for a few weeks, id like to graph the Temps over time to test that out. Everytime i do, i get no data to display.. Any ideas?
Re: Uapp Graph shows no Data to display always.
Posted: Mon Oct 26, 2020 7:39 am
Your controller is not sending data to the server.
Posted: Mon Oct 26, 2020 8:03 am
by SouthernReefer
rimai wrote:Your controller is not sending data to the server.
Interesting... OK so how do i get it to send? Cloud works otherwise, It allows me full control, but id like to get that working if we can. Im cycling so nows the time to get it working :)
Posted: Tue Oct 27, 2020 7:21 pm
That's odd. Did you try rebooting the controller?
Posted: Wed Oct 28, 2020 4:17 pm
by SouthernReefer
rimai wrote:That's odd. Did you try rebooting the controller?
Yes actually I rebooted it yesterday as it was locked up. As a side note how can I tell what's locking it up? The screen was unresponsive and a timeout in Uapp. Reboot fixed it tho. Either way is there a way to troubleshoot why I wouldn't be sending data?
Posted: Wed Oct 28, 2020 4:30 pm
Are you able to connect the controller to a computer and open serial monitor?
Posted: Wed Oct 28, 2020 6:24 pm
by SouthernReefer
rimai wrote:Are you able to connect the controller to a computer and open serial monitor?
I'd have to take it off the side of the tank and essentially take the tank offline, as I don't have a laptop or a pc close to the controller.
Posted: Thu Oct 29, 2020 11:09 am
by SouthernReefer
If it helps. Network wise I am conencted to a Mesh wifi adapter that is then connected back to my Netgear router wirelessly though their protocol. cloud works well.
The only issues im seeing right now, is that im not getting data to you, which concerns me from an alerting standpoint going forward, and ive froze up a couple times.
I did the standard web wizard setup, but i didnt see anything for that in there.
Posted: Fri Oct 30, 2020 10:08 am
The last log shows 9/28.
Nothing after that. Was anything changed during that time?
Posted: Fri Oct 30, 2020 10:29 am
by SouthernReefer
rimai wrote:The last log shows 9/28.
09-28-20 was when we worked through the issues with AVRDUDE to get my code pushed. that was my first code push, and then i got cloud working. I can move my all in one out to the tank if i need to, but will that kill my relay box running the tank while we monitor?
Posted: Fri Oct 30, 2020 10:31 am
by SouthernReefer
Im also assuming this is why the ATO alerts ive configured have not sent me emails too, while i was testing.
Posted: Fri Oct 30, 2020 10:44 am
by SouthernReefer
Also is there a step by step guide to get the logs for you, or is is something that we need to coordinate so I do it while you watch your side? Just want to make sure i catch everything right, as i can setup a temp station for PC tonight.
Posted: Fri Oct 30, 2020 11:28 am
by SouthernReefer
I e run a test direct cable vs my netgear adapter to see if it's that causing issuesm let me know of you suddenly see logs.
Posted: Fri Oct 30, 2020 11:45 am
I don't think it made a difference. Last log is still 09/28.
The alerts are not firing because the server never got data to fire the alerts.
All you need to do is connect the controller on your computer and open serial monitor on Arduino IDE.
The controller will start logging stuff. Wait about 10 to 15 minutes to make sure we catch a couple tries of the controller trying to send data.
Posted: Fri Oct 30, 2020 11:57 am
by SouthernReefer
rimai wrote:I don't think it made a difference. Last log is still 09/28.
And then just send you the output?
Posted: Fri Oct 30, 2020 11:59 am
Yes
Posted: Fri Oct 30, 2020 12:02 pm
by SouthernReefer
rimai wrote:Yes
Ok. I will do this aftwr work. I'll have to move the PC out there but I can make that work I think so I don't have to unplug everything to get this accomplished.infofured network was worth a test, but clearly wired direct to main wifi router makes no difference.
Posted: Fri Oct 30, 2020 12:03 pm
by SouthernReefer
rimai wrote:Yes
Posted: Fri Oct 30, 2020 1:48 pm
by SouthernReefer
Here is the serial
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
Channel 5MQTT succeeded
Channel 5all:0
Channel 5Portal Call
Channel 5Data Sent
Channel 5HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 30 Oct 2020 20:24:07 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ÿDisconnected
Channel 5Connecting...
Channel 5Connected
Date: Fri, 30 Oct 2020 20:24:08 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Disconnected
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:29:08 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:29:10 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:34:09 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:34:10 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:39:10 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:39:11 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:44:12 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:44:13 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5
Posted: Fri Oct 30, 2020 2:17 pm
Definitely something going on there.
Can you please post your code?
Posted: Fri Oct 30, 2020 2:24 pm
by SouthernReefer
rimai wrote:Definitely something going on there.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port7Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
ReefAngel.Relay.DelayedOn( Box1_Port4,10 );
ReefAngel.Relay.DelayedOn( Box1_Port6,10 );
ReefAngel.SingleATO( true,Box1_Port7,45,0 );
ReefAngel.StandardLights( Box1_Port8,22,0,10,0 );
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
if ( ReefAngel.Params.Temp[ T1_PROBE ] >= 820 ) ReefAngel.Relay.Off( Port1 );
if ( ReefAngel.Params.Temp[ T1_PROBE ] <= 775 ) ReefAngel.Relay.On( Port1 );
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX18SRGs3W6Nho4tbkPQm9kNx1zw1++/r4LSB5npUkT/wWfcMeCtcWzAq
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT16=Skimmer
// RA_LABEL LABEL_PORT14=Dosing Pump
// RA_LABEL LABEL_PORT17=ATO
// RA_LABEL LABEL_PORT15=PowerHeads
// RA_LABEL LABEL_PORT13=Return Pump
// RA_LABEL LABEL_PORT18=Cheato Reactor Light
// RA_LABEL LABEL_PORT11=Heater Controller
// RA_LABEL LABEL_PORT12=Cheato Reactor
Posted: Fri Oct 30, 2020 2:37 pm
by SouthernReefer
i have 2 code sets that i had started with im 99 percent sure the one i posted is what is on there. Is there a way to tell which one i actually uploaded to make sure im 100 percent good?
Posted: Fri Oct 30, 2020 4:56 pm
There is no way to find out which code you have.
I also cannot replicate the problem. I tried the exact same code and it connects fine for me.
Can you try creating a new forum username and password?
I am not sure if this will work, but it is worth a try.
The only thing different is the username and password, because I used the exact same code.
Posted: Fri Oct 30, 2020 4:59 pm
by SouthernReefer
rimai wrote:There is no way to find out which code you have.
Will that break anything? Will I need to re upload code? Does it maybe not like special characters?
Posted: Fri Oct 30, 2020 5:06 pm
by SouthernReefer
Could it be something my ISP is blocking as well?
Posted: Fri Oct 30, 2020 5:09 pm
You would need to generate a new code.usimg the new username and upload it to the controller.
Posted: Fri Oct 30, 2020 5:18 pm
by SouthernReefer
rimai wrote:You would need to generate a new code.usimg the new username and upload it to the controller.
I tried to create a new account using same email and it won't let me. That's my only email address.
Posted: Fri Oct 30, 2020 5:37 pm
Ok, let's try this....
Login with the username and password I PM you.
Load the code below and open serial monitor.
Let's see if it makes any difference.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
Port1 );
Port1 );
// RA_STRING1=U2FsdGVkX19jYtoXu4XqRVPLLcwq6OqB5Y/7iQ0mRvU=
// RA_STRING2=null
// RA_STRING3=null
Posted: Fri Oct 30, 2020 5:44 pm
by SouthernReefer
rimai wrote:Ok, let's try this....
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
Port1 );
Port1 );
// RA_STRING2=null
// RA_STRING3=null
Doing it now.
Posted: Fri Oct 30, 2020 5:55 pm
by SouthernReefer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
Port1 );
Port1 );
// RA_STRING2=null
// RA_STRING3=null
No Dice....
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
Channel 5Data Sent
Date: Sat, 31 Oct 2020 00:53:28 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Sat, 31 Oct 2020 00:53:29 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5D
