T2 and T3 Temp Probes
Posted: Sat Jan 30, 2021 9:34 pm
I finally swapped out my head unit with one bought some time ago, I also put 3 new temp probes, two new floats, and a new PH probe.
Of course the room temp probe (the shortest one) ended up at T1, which I modified the following code per another post I saw
The issue is that my T2 and T3 probe indications on the head unit, as well as in the app, will briefly flash to zero and return to the correct temp. T1 seems to not have any issue and is rock solid.
I have stripped out a lot of code I was using, any thoughts why this is occurring?
ReefAngel.StandardHeater(T3_PROBE, Port7 ,InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());I have stripped out a lot of code I was using, any thoughts why this is occurring?
boolean RST;
byte DCPSpeed = 100;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit | Port8Bit;
//ReefAngel.DCPump.FeedingSpeed=0;
//ReefAngel.DCPump.WaterChangeSpeed=0;
ReefAngel.Relay.On( Port3 ); //VarioS8
// initialize default values for Custom Variables
//ReefAngel.CustomVar[4]=100; //speed
//initialize reset flag to true for calculations
RST = true;
void loop(){
//Alkalinity Drip // Currently set to 8 sec every 240 minutes = 36 ml/day (1/15/18) was 31.5
if (ReefAngel.Params.PH < 840) {
ReefAngel.DosingPumpRepeat(Port1, 15,
InternalMemory.DP1RepeatInterval_read(),
InternalMemory.DP1Timer_read());
//Calcium Drip // Currently set to 7 sec every 240 minutes = 31.5 ml/day (1/15/18) was 27
ReefAngel.DosingPumpRepeat(Port2, 45,
InternalMemory.DP2RepeatInterval_read(),
InternalMemory.DP2Timer_read());
ReefAngel.Relay.DelayedOn( Port4 ); //Reef Octopus Skimmer
//ReefAngel.StandardHeater( Port7 ); //Ehiem 150W Heater
ReefAngel.StandardATO( Port8 ); //MAXI Jet 600 ATO Pump
ReefAngel.PWM.Channel1PWMSlope(); //Right & Left Philips Rebel ES Royal Blue and Cool White & UV & Cree XT-E Green
ReefAngel.PWM.Channel2PWMSlope(); //Right Daylight Cree XP-G2 R5 Cool White
ReefAngel.PWM.Channel3PWMSlope(); //Right Actinic Cree XT-E Royal Blue
ReefAngel.PWM.Channel4PWMSlope(); //Left Daylight Cree XP-G2 R5 Cool White
ReefAngel.PWM.Channel5PWMSlope(); //Left Actinic Cree XT-E Royal Blue
//PWM Expansion Channels = 0 if Overheat or Lights off
if ((hour()>=InternalMemory.StdLightsOffHour_read() || hour()<=InternalMemory.StdLightsOnHour_read()) || (ReefAngel.Params.Temp[T3_PROBE]>InternalMemory.OverheatTemp_read())) {
ReefAngel.PWM.SetChannel (1,0);
ReefAngel.PWM.SetChannel (2,0);
ReefAngel.PWM.SetChannel (3,0);
ReefAngel.PWM.SetChannel (4,0);
ReefAngel.PWM.SetChannel (5,0);
//Fuge Light on 1 hour before sunset hour and off 1 hour after sunrise hour
if (hour()>=((InternalMemory.StdLightsOffHour_read()-1) || hour()<=(InternalMemory.StdLightsOnHour_read()+1))) ReefAngel.Relay.On(Port6);
else ReefAngel.Relay.Off(Port6);
// moonlight are on between sunset hour and sunrise hour
if (hour()>=((InternalMemory.StdLightsOffHour_read()-1) || hour()<=InternalMemory.StdLightsOnHour_read())) ReefAngel.PWM.SetChannel (0, (map(MoonPhase(), 0,100,10,25)));
else ReefAngel.PWM.SetChannel (0,0);
//Start Feeding Mode at 17:00 (hour*60*60)
//if ( (now()%86400==61200) /*|| (now()%86400==39600) */) ReefAngel.FeedingModeStart();
//LED fans
if (hour()<InternalMemory.StdLightsOnHour_read() || hour()>(InternalMemory.StdLightsOffHour_read()+1)) ReefAngel.Relay.Off(Port5);
else ReefAngel.Relay.On(Port5);
//DC Pump Speed Normal
ReefAngel.PWM.SetActinic( DCPSpeed );
//Custom Variables and Calculations for Dosing and Lighting Durations
if (RST == true) {
//if ( (now()%86400==3600) || RST == true ) {
//ReefAngel.PWM.SetActinic ( ReefAngel.CustomVar[4] );
int DailyAlk = ((InternalMemory.DP1Timer_read() * (.75)) * (1440 / InternalMemory.DP1RepeatInterval_read())); //Alk ml/day
int DailyCalc = ((InternalMemory.DP2Timer_read() * (.75)) * (1440 / InternalMemory.DP2RepeatInterval_read())); //Calc ml/day
if (DailyAlk!=ReefAngel.CustomVar[0]) ReefAngel.CustomVar[0]=DailyAlk;
if (DailyCalc!=ReefAngel.CustomVar[1]) ReefAngel.CustomVar[1]=DailyCalc;
RST = false;
//assignmenets are = and comparisons are ==
ReefAngel.Portal( "clw143" );
