Page 1 of 2
Reef Angel Installer 0.9.0 released
Posted: Mon Feb 13, 2012 9:18 am
Hello Everyone,
I'm very happy to announce that the new Reef Angel Installer 0.9.0 is released.
You can download it at http://www.reefangel.com/Download.ashx
What is included:
  • Arduino 1.0
  • Development Libraries v0.9.0
  • RAGen for v0.9.0 libraries
  • Graphical Wifi Utility
What you should know:
The new Arduino 1.0 required us to make some changes to the libraries. We took this to also make some changes of our own for future compatibility with new hardware.
This means that your code will not compile with the new libraries and will need some minor changes, which will be explained in a later post.
Before Installing the software:
Before you update your software, make sure to backup your custom header files (ReefAngel_Features.h and ReefAngel_CustomColors.h) if you have made any changes to it.
Then, uninstall the previous Installer and RAGen software you have in your computer.
This will ensure that the software and libraries will work accordingly and you won't have duplicate software installed in your computer. The older version of installer and RAGen will be incompatible with the new software and libraries.
Installing the Software:
After downloading it, simply double-click the file to start the installation.
Follow the steps on the screen.
Re: Reef Angel Installer 0.9.0 released
Posted: Mon Feb 13, 2012 6:02 pm
by rossbryant1956
Is this the new libraries Binder referred to last nite when he said this new version will allow us to individually address the temp sensors, regardless of the address inscribed at the factory? If yes, REALLY COOL.
Posted: Mon Feb 13, 2012 6:14 pm
yes it is. i am working on a post to describe changes and how to use the new stuff plus what all is needed to upgrade. i am a little slow at it due to my work schedule today and tomorrow. i should have the post out tonight hopefully. if not, it will be tomorrow.
Posted: Tue Feb 14, 2012 12:00 pm
by rossbryant1956
1. Has Dave Moltons client software been tested against this release?
2. Will existing documentation (specifically the wireless installation guide) still work or do I need something else.
Thx
Posted: Tue Feb 14, 2012 12:11 pm
1. No, not tested yet.
2. If you have wifi setup, there is nothing to be changed or modified. If you have not setup your wifi, the manual has been updated to make it easier to understand and set it up. You can donwload at http://www.reefangel.com/Download.ashx
Posted: Wed Feb 15, 2012 9:32 pm
I did a quick test and almost everything seemed to be working good with the RA Client, with exception of the expansion relay boxes that didn't show up.
Posted: Thu Feb 16, 2012 6:22 am
by Sebyte
Hi,
If I wanted to keep the old REgen and Dev Libs. for a while, would it be ok to carry out a default 0.9.0 installation to a different drive on my system? Or would there be conflicts due to registry values?
Posted: Thu Feb 16, 2012 6:32 am
RAGen uses "most" of the same registry values. The Main Relay and Controller Tab are new and have their own Registry locations. The new RAGen ONLY uses the Documents\Arduino, Documents\Arduino\libraries folder, Program Files\Reef Angel Controller folder locations.
The new RAGen will auto-detect what version of the libraries you have installed and will generate the appropriate file for you. So there is no problem with the new RAGen working with the old libraries.
The old libraries will not work with the new Arduino. So you have to use the old arduino with the old libraries.
As far as the other stuff goes, I can't answer that because I don't know of the other stuff (if any) that the installer does.
Posted: Thu Feb 16, 2012 8:50 am
by Sebyte
Thanks Curt for comments.
Posted: Thu Feb 16, 2012 9:19 am
You don't need to install the 0.9.0 if you want to keep the previous version for now.
May I ask why you would want to install 0.9.0 in a different drive?
Is it to just try to play around and try to compile some codes?
Posted: Thu Feb 16, 2012 1:31 pm
by Sebyte
Curt,
Exactly, I was thinking of looking at the comparison code. Hopefully it would help build my understanding. The registry is a limitation of windows, I was wondering if setting up a virtual machine might get around the issue.
Call me a wimp, but I don't want the screw up the registry as it is such a pain to sort out :?
Posted: Thu Feb 16, 2012 8:45 pm
The registry stuff isn't bad to worry about. My registry settings are consolidated and you can't really screw much stuff up. The registry is just to save the settings and not needed for normal usage.
Code comparison won't really lead to much differences. The functions are virtually the same. There has just been some more stuff added in 0.9.0.
Virtual machine would work just fine with testing things with it. You could run it in a VM and then force the 0.8.5.X and 0.9.0 libraries and compare the code side-by-side.
Posted: Sun Feb 19, 2012 12:51 am
by aranax
Hey Curt/Robert,
Can you guys please help me get my old sketch up and running? I'm having a bunch of issues converting this.
Here are the errors I'm getting:
New_v1.cpp: In function 'void DrawCustomMain()':
New_v1:39: error: 'struct ParamsStruct' has no member named 'Temp1'
New_v1:41: error: 'struct ParamsStruct' has no member named 'Temp2'
New_v1:43: error: 'struct ParamsStruct' has no member named 'Temp3'
New_v1:73: error: 'PWMChannel' was not declared in this scope
New_v1:73: error: 'LEDPWM0' was not declared in this scope
New_v1:74: error: 'LEDPWM1' was not declared in this scope
New_v1:75: error: 'LEDPWM2' was not declared in this scope
New_v1:76: error: 'LEDPWM3' was not declared in this scope
New_v1.cpp: In function 'void loop()':
New_v1:129: error: 'PWMChannel' was not declared in this scope
New_v1:129: error: 'LEDPWM3' was not declared in this scope
New_v1:129: error: 'Moonphase' was not declared in this scope
New_v1:133: error: 'LEDPWM0' was not declared in this scope
New_v1:134: error: 'LEDPWM1' was not declared in this scope
New_v1:135: error: 'LEDPWM2' was not declared in this scope
New_v1.cpp: In function 'void CheckCloud()':
New_v1:293: error: 'PWMChannel' was not declared in this scope
New_v1:304: error: 'PWMChannel' was not declared in this scope
New_v1:305: error: 'PWMChannel' was not declared in this scope
New_v1:310: error: 'PWMChannel' was not declared in this scope
And here is the sketch I'm trying to convert:
// Autogenerated file by RAGen (v1.2.1.158), (02/18/2012 22:40)
// RA_021812_2240.ino
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
  ReefAngel.LCD.DrawDate(6, 120);
  ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15, 10, "T1:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, T1TempColor, 15+18, 10, 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 15, 10+10, "T2:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, 15+18, 10+10, 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 15, 10+20, "T3:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, 15+18, 10+20, 10);
  ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+60, 10, "PH:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, 15+78, 10, 100);
  //ATO status
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15+60, 10+20, "Pump:");
  byte highcolor;
  char highstatus[10];
  if ( ReefAngel.HighATO.IsActive() )
       ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+90, 10+20, "ON ");
       ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15+90, 10+20, "OFF");
  //End ATO status
  ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
  ReefAngel.LCD.DrawText(0,255,15,52,"RB:");
  ReefAngel.LCD.DrawText(0,255,15,62,"BB:");
  ReefAngel.LCD.DrawText(0,255,15,72,"CW:");
  ReefAngel.LCD.DrawText(0,255,15,82,"WW:");
  ReefAngel.LCD.DrawText(0,255,15+20,52,PWMChannel[LEDPWM0]);
  ReefAngel.LCD.DrawText(0,255,15+20,62,PWMChannel[LEDPWM1]);
  ReefAngel.LCD.DrawText(0,255,15+20,72,PWMChannel[LEDPWM2]);
  ReefAngel.LCD.DrawText(0,255,15+20,82,PWMChannel[LEDPWM3]);
    ReefAngel.LCD.DrawGraph(5, 5);
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port2);
    // Specific functions
    ReefAngel.StandardLights(Port4);
    ReefAngel.Relay.DelayedOn(Port5, 2);
    ReefAngel.MHLights(Port8);
    ReefAngel.Portal("aranax");
    if(ReefAngel.HighATO.IsActive())
        ReefAngel.Relay.DelayedOn(Port1,1);
        ReefAngel.Relay.Off(Port1);
    //skimmer
    if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.DelayedOn(Port5,1);
    else ReefAngel.Relay.Off(Port5);
    //refugium
    if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.Off(Port6);
    else ReefAngel.Relay.On(Port6);
    if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.On(Port7);
    else ReefAngel.Relay.Off(Port7);
     PWMChannel[LEDPWM3]=Moonphase();
  // Calculate your regular sunrise/sunset PWM value
  PWMChannel[LEDPWM0]=PWMSlope(12,30,22,00,0,80,240,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(12,00,22,15,0,70,240,PWMChannel[LEDPWM1]);
  PWMChannel[LEDPWM2]=PWMSlope(13,30,21,30,0,30,180,PWMChannel[LEDPWM2]);
  PWMChannel[LEDPWM3]=PWMSlope(15,0,23,00,0,60,180,PWMChannel[LEDPWM3]);
  //PWMChannel[LEDPWM0]=PWMSlope(16,30,21,00,0,80,120,PWMChannel[LEDPWM0]);
  //PWMChannel[LEDPWM1]=PWMSlope(16,00,21,15,0,70,120,PWMChannel[LEDPWM1]);
  //PWMChannel[LEDPWM2]=PWMSlope(17,30,20,30,0,30,60,PWMChannel[LEDPWM2]);
  //PWMChannel[LEDPWM3]=PWMSlope(16,0,21,00,0,60,120,PWMChannel[LEDPWM3]);
  CheckCloud();
  PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(13 ,30)
#define End_Cloud_Before NumMins(18,30)
#define Lightning_Change_per_Cloud 60
  // Channels used by the actinic LEDs on the PWM Expansion module
  // These channels will not be dimmed when the cloud effect is triggered
  // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
  // Channels used by the daylight LEDs on the PWM Expansion module
  // These channels will be used for the spike when lightning effect is triggered
  // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B001110
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      // let's go through all channels to pick which ones will be dimmed
      for (int a=0;a<6;a++)
        if (bitRead(Actinic_Channels,a)==0)
          // this will slope down the channel from the current PWM to 0 within 3minutes.
          // then it will stay at 0 for the duration of the cycle
          // and finally slope up from 0 to PWM value within 3 minutes
          // it is basically an inversed slope
          PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
        for (int b=0;b<6;b++)
          if (bitRead(Daylight_Channels,b)==1)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,50,93,90);
    ReefAngel.LCD.DrawText(0,255,15+60,52,"CD:");
    ReefAngel.LCD.DrawText(0,255,15+60,62,"NC:");
    ReefAngel.LCD.DrawText(0,255,15+80,62,cloudindex);
    ReefAngel.LCD.DrawText(0,255,24+80,62,"of");
    ReefAngel.LCD.DrawText(0,255,38+80,62,numclouds);
    ReefAngel.LCD.DrawText(0,255,15+60,72,"CS:");
    ReefAngel.LCD.DrawText(0,255,15+80,72,"00:00");
    ReefAngel.LCD.DrawText(0,255,15+60,82,"LS:");
    ReefAngel.LCD.DrawText(0,255,15+80,82,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=95; else x=98;
      ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart/60));
      if ((cloudstart%60)>=10) x=113; else x=119;
      ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,15+80,52,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=95; else x=58;
      ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=113; else x=119;
      ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))%60));
Posted: Sun Feb 19, 2012 7:21 am
There were several changes that were needed to be made. Here's a list of the changes that I made for you.
  • Temp1 ==> Temp[T1_PROBE]
  • Temp2 ==> Temp[T2_PROBE]
  • Temp3 ==> Temp[T3_PROBE]
  • Move Portal() to above ShowInterface()
  • Move ShowInterface() to be last line in loop()
  • Add LEDPWM defines back to code
  • Changed Moonphase() to MoonPhase()
  • Added PWMChannel[] array back to code
I think there are some improvements that could be made with the PWM Expansion stuff since some of the functions have now been incorporated into the libraries, but I'm simply going with the "if it's not broke, don't fix it" unless Roberto makes those changes. :)
This should work now.
Ok, here's the code:
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
// LEDPWM Channel defines for easy code reading
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup.
byte PWMChannel[]={0,0,0,0,0,0};
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, 15+18, 10, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 15+18, 10+10, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor, 15+18, 10+20, 10);
  //ATO status
  byte highcolor;
  //End ATO status
    // PWM Slope functions for PWM Channels on RA Head unit
    //skimmer
    //refugium
     PWMChannel[LEDPWM3]=MoonPhase();
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      int x=0;
      int x=0;
Posted: Sun Feb 19, 2012 10:50 am
by aranax
Thanks Curt. I got further but I'm still having some errors.
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void processHTTP()':
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:325: error: 'class ReefAngelClass' has no member named 'PWM'
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void SendXMLData(bool)':
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:862: error: 'class ReefAngelClass' has no member named 'PWM'
I had to change:
wire.send to wire.write
commented out (since I don't use the headunit PWM channels)
//ReefAngel.PWM.ActinicPWMSlope();
//ReefAngel.PWM.DaylightPWMSlope(); in the sketch file since I don't use the hadunit PWM channels
commented out (sketch was too big):
//#define DateTimeSetup
//#define VersionMenu
//#define DisplayLEDPWM
//#define WDT
Can you please help? Thanks again.
-J
Posted: Sun Feb 19, 2012 10:53 am
You need
even though you don't use the PWM on the head unit. Since you have the Expansion Module and have PWMExpansion, you MUST include DisplayLEDPWM. That's why you are getting the error.
Posted: Sun Feb 19, 2012 11:10 am
by aranax
Thanks again Curt. I was commenting out everything I could since I'm getting the sketch too big error.
I had to ditch the storm effects :( in my file to get it to fit.
Posted: Sun Feb 19, 2012 11:25 am
by aranax
I just compiled and everything compiled correctly. I just finished uploading and now my RA headunit says "No Internal Memory Found".
Everything sent fine:
avrdude: Send: t [74] . [00] . [80] F [46]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] f [66] . [85] w [77] . [85] . [80] . [ea] . [95] . [e0] J [4a] . [e0] P [50] . [e0] . [0e] . [94] . [b3] 9 [39] . [8c] . [e4] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [80] . [ea] . [95] . [e0] . [b7] . [01] . [0e] . [94] . [c6] 9 [39] . [81] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] . [e6] W [57] . [ff] O [4f] . [80] . [ea] . [95] . [e0] ` [60] . [81] J [4a] . [e0] P [50] . [e0] . [0e] . [94] a [61] 9 [39] . [86] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] . [e5] W [57] . [ff] O [4f] . [80] . [ea] . [95] . [e0] ` [60] . [81] J [4a] . [e0] P [50] . [e0] . [0e] . [94] a [61] 9 [39] . [8c] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [80] . [ea] . [95] . [e0] . [b6] . [01] . [0e] . [94] . [c6] 9 [39] . [82] . [e6] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [c8] . [01] . [81] . [96]
avrdude: Recv: . [10]
avrdude: Send: U [55] . [00] , [2c]   [20]
...deleted stuff....
avrdude: Send: U [55] . [c0] = [3d]   [20]
avrdude: Send: t [74] . [00] . [04] F [46]   [20]
avrdude: Recv: . [81] 7 [37] . [ca] 7 [37]
# | 100% 14.98s
avrdude: verifying ...
avrdude: 31620 bytes of flash verified
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
Please help...again :). Thanks.
-J
Posted: Sun Feb 19, 2012 11:39 am
The "No Internal Memory Found" error is a new one that was added into the libraries for 0.9.0. You will need to use RAGen to generate a new Internal Memory file to upload OR use the included InternalMemory file to upload.
There is a value that is set in the internal memory that the controller looks for on startup. This will prevent people from accidentally forgetting to upload the Internal Memory first. The downside is that all people who are upgrading will have to set this value otherwise they will get this error.
If you don't have your initial internal memory file, then you can simply load this one to fix. It will not erase your values in internal memory, it will only tell the libraries that you have your memory set.
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    // display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, "   RA code file");
    delay(5000);
It is recommended that you load the initial values again to make sure that you don't try to use a feature that is new, but if nothing on your controller has changed other than you upgrading this will fix that problem.
Posted: Sun Feb 19, 2012 12:11 pm
by aranax
Thanks Curt. I'm back up and running. As usual, the support you guys provide is top notch. Thanks again.
-J
Posted: Sun Feb 19, 2012 12:21 pm
aranax wrote:Thanks Curt. I'm back up and running. As usual, the support you guys provide is top notch. Thanks again.
-J
Awesome. :D Glad you are up and running again.
Posted: Mon Feb 20, 2012 12:54 am
by aranax
Hey guys,
Everything works but...is it possible that you "fixed" a bug that now causes my drivers to blink? I have the meanwell "P" drivers that only work from 15% to 100% but I never had a problem running these at ~5% to 15%. I thought I got lucky as they worked between 5% and 15% without issue (no blinking). Since I updated, I'm running into the "expected" below 15% "blinking". I didn't change anything from a hardware standpoint so I don't know what it could be.
I had to change my PWMSlope from:
to
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM0]=0;
else PWMChannel[LEDPWM0]=PWMSlope(12,30,22,00,15,80,240,PWMChannel[LEDPWM0]);
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM1]=0;
else PWMChannel[LEDPWM1]=PWMSlope(12,00,22,15,15,70,240,PWMChannel[LEDPWM1]);
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM2]=0;
else PWMChannel[LEDPWM2]=PWMSlope(12,00,22,15,15,50,240,PWMChannel[LEDPWM2]);
if (hour()>22 && hour()<4)PWMChannel[LEDPWM3]=MoonPhase();
else PWMChannel[LEDPWM3]=PWMSlope(15,0,22,00,15,60,180,PWMChannel[LEDPWM3]);
Does this make sense or did I make a mistake? Thanks.
-J
Posted: Mon Feb 20, 2012 9:55 am
Nothing was changed for those.
Posted: Mon Feb 20, 2012 3:45 pm
by JoshSD
On a machine that previously did not have any RA software installed (XP SP3) I installed the 0.9.0 package from the download page, which installed with no errors. As an initial test, I opened RA Generator, and selected the items similar to my running sketch (which was done on another machine). After saving from RA Generator, and launching arduino 1.0, I tried to compile the sketch and got this error:
C:\Documents and Settings\Admin\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void SendXMLData(bool)':
C:\Documents and Settings\Admin\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:982: internal compiler error: Illegal instruction
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://sourceforge.net/tracker/?atid=52 ... unc=browse> for instructions.
The specific error changes if I select different options on the Controller tab in Generator. Removing the wifi option throws this compiler error instead:
C:\Program Files\Reef Angel Controller\libraries\Wire\Wire.cpp: In member function 'virtual size_t TwoWire::write(const uint8_t*, size_t)':
C:\Program Files\Reef Angel Controller\libraries\Wire\Wire.cpp:264: internal compiler error: Illegal instruction
I tried to reset to the default values and remove the features I'd checked (Watchdog, ATO logging, direct temp sensor) but got the same error after saving and compiling.
RA Generator -> Show Library Version displays Version 0.9.0.
Any suggestions? Thanks in advance.
Posted: Mon Feb 20, 2012 4:07 pm
I have not seen these errors before.
Posted: Mon Feb 20, 2012 4:22 pm
by JoshSD
rimai wrote:I have not seen these errors before.
thanks for the quick reply. Are there any other prerequisites to the 0.9.0 installer?
Posted: Mon Feb 20, 2012 4:25 pm
No.
Everything should've been installed for you.
Posted: Mon Feb 20, 2012 8:09 pm
by JoshSD
OK, no worries. I will do the configuration work on a more modern machine. The one that is throwing the errors is an older industrial PC that I am using to run the client software (works fine) so it may be the hardware that is challenged.... it's a 500MHz Via processor with 512 MB RAM :) ...
Thanks again for the quick reply. I've been really impressed with your support.
Posted: Mon Feb 20, 2012 8:51 pm
by JoshSD
JoshSD wrote:OK, no worries. I will do the configuration work on a more modern machine.
This did the trick; no problems on a different PC.
Posted: Mon Feb 20, 2012 8:53 pm
Glad you got it working and thanks for sharing that old computers may have issues.
