problem uploading to board
Posted: Mon Feb 13, 2012 6:22 pm
by Knightly
Hi, I have a new reefangel. Loaded code with no problems until last night.
I get the following
I have controller with Optiboot selected.
Bob
vrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
Using Port : \\.\COM5
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done. Thank you.
Bob
Re: problem uploading to board
Posted: Mon Feb 13, 2012 7:38 pm
Do you mean it was uploading before and now you get errors?
Posted: Tue Feb 14, 2012 8:08 pm
by Knightly
Hi,
Yes, the unit was uploading without problems.
odd thing is the unit will sometimes upload, may 1 in 10 times.
Any idea?
Bob
Posted: Tue Feb 14, 2012 9:09 pm
by Knightly
HI,
found the problem. solder joints on X2 connector. 2 solder joints cracked.
Everything works now.
thanks,
Bob
