Custom Menu and Main Screen Compile Error
Posted: Mon Feb 13, 2012 7:35 pm
by SuperDodge
I am trying to add a custom menu and main screen to my new pde file.
When compiling I keep getting two errors:
'DefaultBGColor' was not defined in this scope
And
no matching function for call to 'ReefAngel_NokiaLCD::DrawMonitor(int, int, ParamStruct&) '
What newbie error am I making?
Re: Custom Menu and Main Screen Compile Error
Posted: Mon Feb 13, 2012 7:56 pm
DefaulBGColor, should be DefaultBGColor
The DrawMonitor error is because you have "DisplayLEDPWM" on your features. Remove it and you will be fine.
Posted: Mon Feb 13, 2012 8:03 pm
by SuperDodge
Uh Oh. So now I get the error 'class ReefAngelClass' has no member named 'PWM'
I assume this is because I removed DisplayLEDPWM from my features?
I was using a line here to sound a buzzer plugged into my Actinic Port. I have commented out the following line for now, but is there an alternative way to sound the buzzer?
ReefAngel.PWM.SetActinic(100);
Posted: Mon Feb 13, 2012 8:14 pm
Oh sorry...
I thought you weren't using it.
Put it back in and replace the line:
ReefAngel.LCD.DrawMonitor(15, 66, ReefAngel.Params);
With this:
ReefAngel.LCD.DrawMonitor(15, 66, ReefAngel.Params,ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
Posted: Mon Feb 13, 2012 8:22 pm
by SuperDodge
Thanks for the quick reply Roberto. My RA is just getting better and better.
