WIFI PB with French Box "Freebox Révolution"
Posted: Tue Feb 14, 2012 12:30 am
Hello,
I just changed my provider box and now the Wifi module seems to don't want to connect.
Do you know if my access point is compatible with the Wifi attachment ?
Before I had the previous version of the box (called V5 http://fr.wikipedia.org/wiki/Freebox#Wi-Fi).
The Wifi configuration didn't change. It's configured in the admin provider web configuration (When you reboot your box, it push the configuration what ever your box is).
My box : Wi-Fi 802.11n MIMO 3x3 / 2,4 GHz (450 Mb/s max) Card mini PCI Express Marvell 88W8366
I'm in WPA2 (TKIP)
SSID : "xender"
key : ********
DHCP : ON
Wifi Graphical utility :
mode 4
port : 2000
Logs :
No IP
AUTH-error
I have the V6 Version called "FreeBox Révolution" : http://en.wikipedia.org/wiki/Freebox
FR version more complete :http://fr.wikipedia.org/wiki/Freebox
RA Wifi module : http://www.rovingnetworks.com/products/RN_131
Thanks for your help
I'm in WPA2 (TKIP)
SSID : "xender"
key : ********
DHCP : ON
mode 4
port : 2000
Logs :
No IP
AUTH-error
