RA Plus and wifi module
Posted: Wed Feb 07, 2024 8:07 am
Hello,
I am still using an old RA plus with the wifi module and am trying to setup the UApp but am having issues.
I have run the ttl macro on the wifi module but am confused with the section relating to the UAPP setup.
In the user guide it says that to use the RA+ with UAPP you need to use the RA+ 's IP address instead of the cloud user/password info.
When i do this I just get an error stating "error logging in, check username and password"
Also, i used to be able to access the controller locally via the url http://172.16.200.100:2000/wifi but that seems to have stopped wotking and dont know if its related.
Lastly, I also have the old Reef Angel android app on my phone and it is still able to see the controller, updates temps etc and is able to turn relay on/off etc so the RA+ is connected to wifi etc.
Any ideas/help would be appreciated.
thanks
Andy
thanks
Andy
