Driver for Dimming
rafamar
Driver for Dimming
Post by rafamar »
Hello,
im from Italy and today ive buy Reef Angel Controller,
im not a expert about electronics , i would control and dimming this power led:
ht*p://***.ebay*it/itm/10pcs-20W-White-20000K-25000K-High-Power-LED-1800LM-Lamp-Bulbs-lights-Aquarium-/180803356812?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2a18b8488c#ht_1823wt_1110
could you tell me wich driver ive to buy to power it?
this item PWM-to-Analog Lead Wire could be interesting for me?
Thank you in advance!!
8-)
rafamar
Re: Driver for Dimming
Post by rafamar »
probably ive found a good driver:
http://w*w.meanwell.c*m/search/eln-60/default.htm
ELN -60-48 model
it is 60w rated power, so can i connect 3 x 20w led with each power supply?
i need for 64-48 P or D?
last question
ill connect 1 driver(with 3x20W royal blue led) to actinic PWM port;
can i connect 3 drivers(with 3x20w white led each one) together to daylight PWM port?
bye
Yes you can connect multiple drivers in the PWM port. Make sure to use the "P" version of the meanwell driver.
