wifi expansion hub can't connect to cloud
tngo
Hi
I have a wifi expansion hub but am having issues connecting it to the RA cloud. When setting up the expansion hub I use the same setup as the wifi attachment using 192.168.4.1 to setup the wifi and RA cloud login. However once I click save I only get a blinking magenta led meaning it's trying to connect to the RA cloud. My router picks up the expansion hub fine but I can't get past the blinking magenta led. I've tried using unencrypted username/password and encrypted username/password but no luck. Has anyone come across this problem or know what might be causing this? This issue started right around the time when I had to encrypt my password when using the webwizard.
Tim
Tim
- brennyn21
Re: wifi expansion hub can't connect to cloud
Hello, have you updated the device yet?
Sincerely, Brennyn
- brennyn21
Also the username and password should be non encrypted. It's also case sensitive
Sincerely, Brennyn
tngo
I didn't realize that there was and update for this hub. This should be the last device shown on the webwizard correct? I'll give that a try later today. Thanks for all the updates to the ReefAngel system.
Tim
Tim
tngo
Tim
Tim
- brennyn21
For the hub there is a pin hole by the led light, hit that button while it's connected to the Internet and it will update. The Led should turn Yellow and it should work after that.
If you have any troubles let me know! The web wizard is only for very early versions of the cloud hub and cloud wifi module, it sounds like you have the later version of the module so you won't need it
Sincerely, Brennyn
- brennyn21
Sincerely, Brennyn
tngo
I don't see the pin hole that you're referring to. I've attached an image of my board.
Tim
Tim
- brennyn21
Click on AP Reset while its connected to wifi and that will update the device
Sincerely, Brennyn
tngo
Clicking on AP reset causes the hub to blink blue to begin the process to assign the ssid and cloud username and password. Once these are set and saved the hub goes back to blinking magenta.
- brennyn21
You are hitting it when it's connected to WiFi and blinking magenta? So it's never turning yellow?
Sincerely, Brennyn
tngo
Yeah. I have hit the ap reset button many times over the past week trying to see if I could get the hub to connect. It may have updated then and i didn't notice, but the led isn't turning yellow now when I hit the button.
- brennyn21
Let's try factory resetting it and see if that makes a difference. To do that you'll hold the ap Reset button while plugging in the power cable.
Sincerely, Brennyn
tngo
I did the factory reset but after entering the wifi and cloud credentials the hub led still blinks magenta.
- brennyn21
Interesting... blinking magenta means issues with the user account. For the username you are using "tngo" all lowercase? And your forum password?
Sincerely, Brennyn
tngo
Yes that is correct.
tngo
The password is unencrypted correct?
- brennyn21
Yes just your normal forum password unencrypted. Case sensitive
Sincerely, Brennyn
javisaman
I believe I am having the same issue since April 11th with the magenta light. The uapp was working fine since then. However, I'm away from my tank for a few days and won't be able to debug. Is there a chance there is something wrong on the server end?
- brennyn21
I am going through the logs to see if I can an issue. I will let you know
Sincerely, Brennyn
javisaman
False alarm. I asked my parents to unplug it and plug it back in and its working now!
- brennyn21
Glad to hear, I am making an adjustment to the reconnect function for the cloud WIFI attachment once, I have tested it thoroughly I will push it to the server.
Sincerely, Brennyn
