Hi,
I've noticed recently that the reef angel display on my plus unit is not turning off. I noticed that the joystick was stuck (kept scrolling down), so I cleaned the joystick with contact cleaner and added dielectric grease and it fixed that problem. However, the screen remains on. Is there something else I can try?
Display not turning off
- brennyn21
Re: Display not turning off
It sounds like it still thinks the joy stick is being pressed or moved.
Here is the relevant code in the ReefAngel_1.5_LCD.h
void ReefAngelClass::CheckScreenSaver()
// process screensaver timeout
if ( Timer[LCD_TIMER].IsTriggered() )
// Screensaver timeout expired
LCD.BacklightOff();
if ( Joystick.IsButtonPressed() )
// turn the backlight on
LCD.BacklightOn();
// TODO check Timer[LCD_TIMER] code
if ( Timer[LCD_TIMER].Trigger == 0 )
Timer[LCD_TIMER].Start();
return;
PrepMenuScreen();
// get out of this function and display the menu
return;
#ifdef MAIN_2014
if ( Joystick.IsUp() || Joystick.IsDown() )
#else
if ( Joystick.IsUp() || Joystick.IsDown() || Joystick.IsRight() || Joystick.IsLeft() )
#endif // MAIN_2014
// Turn backlight on
LCD.BacklightOn();
}Sincerely, Brennyn
