Device Logs - Bus Locks?
Posted: Mon Sep 09, 2024 1:54 pm
by Piper
My RA* is constantly beeping at me and I'm guessing rebooting from bus locks. I see the bus locks in the Device Logs section of the uapp but there is no detail on what's locking up. Is there any way to tell what is causing the bus lock and, if so, add that detail to the Device Logs? I'd like to see if I can track down what is causing all of the problems.
Re: Device Logs - Bus Locks?
Posted: Mon Sep 09, 2024 8:12 pm
by brennyn21
So there isn't a way to detect which device is causing the bus locks in software, but you can disconnect one expansion at a time to verify which one is causing the issue.
I've had bus locks due to rust formed on the USB port / cable, as well as when I have the USB cables placed next to my dimming wires from the controller and expansion module.
It is best to keep all Expansion cables away from any power cables to reduce bus locks. Hopefully this helps
Posted: Tue Sep 10, 2024 5:50 am
by Piper
Got it. I'll start messing around with it this weekend and see if I can figure out what is causing it.
