Buzzer for High and Low alarm
Appleseed
Post by Appleseed »
Mornign,
My 2 heaters failed 3 days ago and i didnt notice until yesterday. Luckily the tempos only dropped to 22 so maybe dodged a bullet there.
Anyhow I was trying to setup an audiable alarm but cant get it to compile.
I have tried adding the following to my code but get an error
boolean buzzer=false;
if (ReefAngel.Params.Temp[T1_PROBE] >= 300 || ReefAngel.Params.Temp[T1_PROBE]<= 230) buzzer=true;
if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
The compile error is
Compilation failed for Appleseed.ino: Details: Appleseed.ino: In function 'void setup()': Appleseed.ino:139:25: error: 'class ReefAngelClass' has no member named 'BuzzerOn' Appleseed.ino:139:53: error: 'class ReefAngelClass' has no member named 'BuzzerOff'
I am using an RA Plus.
The entire code is as follows
Andy
// 07-08-2024 editied names and set port 3 to auto on
//#include <RA_ATO.h>
//#include <Wire.h>
//#include <OneWire.h>
//#include <RA_PWM.h>
//#include <Salinity.h>
//#include <IO.h>
//#include <ORP.h>
//#include <AI.h>
//#include <DCPump.h>
// Globals Needed for RF Mode on Custom Main
//byte vtechmode;
//byte vtechspeed;
//byte vtechpercent;
boolean bFeeding = false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//Custom Main, Graph & Menu
  //      ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(3, 255, 6, 2, " Reef of Low");
  ReefAngel.LCD.DrawDate(7, 120);
//  vtechmode = ReefAngel.RF.Mode;
//  vtechspeed = ReefAngel.RF.Speed;
//  vtechpercent = ReefAngel.RF.Duration;
  ReefAngel.LCD.Clear(255, 35, 20, 20, 85);
 // ReefAngel.LCD.DrawText(0, 255, 18, 21, "EcoSmart Mode");
 // if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 25, 31, "Constant");
 // else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, 255, 25, 31, "Lagoonal");
 // else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, 255, 25, 31, "Reef Crest");
 // else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 25, 31, "Short Pulse");
 // else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK, 255, 25, 31, "Long Pulse");
 // else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, 255, 25, 31, "STM_NTM.");
 // else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, 255, 25, 31, "Tidal Swell");
 // else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE, 0, 45, 31, "Night");
//  ReefAngel.LCD.DrawText(2, 255, 32, 42, "Speed");
//  ConvertNumToString(text, vtechspeed, 1);
//  if (vtechspeed )ReefAngel.LCD.DrawLargeText(0, 255, 35, 51, text);
//  ReefAngel.LCD.DrawText(23, 255, 32, 62, "Duration");
//  ConvertNumToString(text, vtechpercent, 1);
//  if (vtechpercent) ReefAngel.LCD.DrawLargeText(0, 255, 35, 70, text);
  ReefAngel.LCD.DrawText(0, 255, 10, 80, "T1");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 88, text, Num8x8);
  ReefAngel.LCD.DrawText(0, 255, 50, 80, "T2");
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 50, 88, text, Num8x8);
  ReefAngel.LCD.DrawText(0, 255, 100, 80, "pH");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 88, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
  ReefAngel.FeedingModePorts = Port4Bit; //| Port6Bit | Port7Bit;
  // ReefAngel.WaterChangePorts = Port4Bit | Port7Bit;
  ReefAngel.Relay.On( Port3 );
  ReefAngel.Relay.On( Port4 );
 // ReefAngel.Relay.DelayedOn( Port4 );
  ReefAngel.Relay.On( Port5 ); //MP40
  ReefAngel.Relay.On( Port6 ); //MP40
  ReefAngel.Relay.On( Port7 ); //Return
 // ReefAngel.Relay.DelayedOn( Port8 ); // Used By Cooling Fan
  //  ReefAngel.DCPump.FeedingSpeed=100;
  //  ReefAngel.Timer[FEEDING_TIMER].SetInterval(2100);
  ReefAngel.Timer[FEEDING_TIMER].SetInterval(4000);
  ReefAngel.StandardHeater( Port1, 250, 255 );
  ReefAngel.StandardHeater( Port2, 250, 255 );
  ReefAngel.StandardFan( Port8, 256, 260 );
// Define Relay Ports by Name
        #define Heater             1
        #define Heater             2
        #define ReefWave25           3
        #define Skimmer          4
        #define MP40          5
        #define MP40           6
        #define Return         7
        #define Fan            8
  ReefAngel.Portal( "Appleseed" );
brennyn21
Re: Buzzer for High and Low alarm
Post by brennyn21 »
This code below is only for the Reef Angel Star as it has a built in buzzer.
The RAPlus does not have a built in internal buzzer so you would need an external one and run it off one of the PWM Channels.
The code you would use is this below
ReefAngel.PWM.SetDaylight( buzzer?0:100 ); // in this example I have it set on the Daylight Channel
Hope this helps.
Sincerely, Brennyn
Appleseed
Post by Appleseed »
Thanks Brennyn, I didnt realise that the Plus didnt have a buzzer :)
Would any 12v buzzer work?
brennyn21
Post by brennyn21 »
Yes 12v buzzer is fine
Sincerely, Brennyn
brennyn21
Post by brennyn21 »
On a side note you can setup alerts in the Uapp to also notify you if a parameter goes out of your desired range
Sincerely, Brennyn
Appleseed
Post by Appleseed »
brennyn21 wrote: Mon Oct 28, 2024 2:12 pm On a side note you can setup alerts in the Uapp to also notify you if a parameter goes out of your desired range
Thanks I already have but thought the buzzer would be an extra safe guard.
