UAPP PROBLEMS
CASPAR
- brennyn21
Re: UAPP PROBLEMS
Do you get an error? Can you try logging out and back in again?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
YES HAVE LOGGED OUT THEN BACK ON AND STILL GET ERROR "FAILED TO REFRESH DATA"
THIS LINE I MADE SURE IS IN MY CODE "ReefAngel.Portal( "CASPAR" );"
CASPAR
Re: UAPP PROBLEMS
UAPP ON PHONE AND COMPUTER DOES NOT REFRESH BUT THE OLD APP ON MY PHONE DOES IN BOTH HOME AND AWAY MODE
- brennyn21
Re: UAPP PROBLEMS
Did your router or port forwarding change? Can you access your controller by going to your publicIP:2000?
Sincerely, Brennyn
CASPAR
CASPAR
Re: UAPP PROBLEMS
ALSO JUST GOT EMAIL NOTIFICATION ABOUT 10 MINUTES AGO THAT SAID REEF ANGEL HAS RE ESTABLISHED CONNECTION, BUT STILL DOESNT WORK
- brennyn21
Re: UAPP PROBLEMS
If you can see the webserver, then it should be working, does it let you change the modes or turn on or off an outlet?
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
I DONT SEE NOTHING BUT THE WORDS REEF ANGEL CONTROL WEB SERVER NOTHING ELSE.
FAR AS CHANGING STATUS OF THE RELAY IT WILL NOT DO THAT EITHER JUST SAYS SOMETHING TO THE EFFECT OF FAILED TO UPDATE COMMAND AT BOTTOM OF SCREEN IN RED
- brennyn21
CASPAR
CASPAR
- brennyn21
Re: UAPP PROBLEMS
I wonder if your IP changed and the Uapp didn't update correctly I will do some investigating. I responded to your PM
Sincerely, Brennyn
CASPAR
Re: UAPP PROBLEMS
MORE THAN LIKELY IP MAY HAVE CHANGED DUE TO SPECTRUM DOING AN OVERNIGHT MAINTENACE THING, AND TRUST ME IT SCREWED UP ALOT OF CRAP!!!
