HI all,
I am trying to set up my wifi, but when I run the wifiUtility I get the error "Unable to find a version of the runtime to run this application" It comes up as a .NET Framework Initialization Error
I am running XP on my Mac, but don't think that is the problem. Have run all the updates. Is there an updated version somewhere?
WifiUtility error
- Contact:
Re: WifiUtility error
You will most likely need the .NET framework installed. I believe you need to have 3.5 installed to have it run properly. Verify you have the .NET framework installed in the Installed Programs in the control panel.
