Page 1 of 3
Custom Web Chart
Posted: Mon Feb 20, 2012 2:36 pm
For those that use custom fields or any other field that is not plotted by the standard web chart, here is an alternative of seeing the web chart for a particular field:
http://forum.reefangel.com/status/chart ... filter=rfw
The example above is my Ecotech Radion White channel using the new PWMParabola() function.
Only two parameters are needed:
id - Your forum id
filter - The filter can be anything in this list:
http://forum.reefangel.com/viewtopic.php?p=5957#p5957
Re: Custom Web Chart
Posted: Tue Nov 27, 2012 2:05 am
by dazza1304
Hi Roberto,
I have tried to access thie first link for the custom web chart but doesn't work - I want to chart my water level expansion.
Can you,help?
Posted: Tue Nov 27, 2012 2:18 am
by dazza1304
Ignore me, just realised I need to add my ID and parameter-all sorted now!
Posted: Mon Mar 04, 2013 5:02 pm
by jsclownfish
How do I filter this for a relay status?
http://forum.reefangel.com/status/chart ... filter=XXX
I finally got around to connecting my homemade lightsensors to the IO unit (
http://forum.reefangel.com/status/chart ... &filter=C0 or C1 for right and left side of the tank ) and I wanted to look at them overlayed with the actual relay units that control the lights.
They seem to work pretty well for a confirmation that the bulbs are working OK.
Jon
Posted: Mon Mar 04, 2013 5:11 pm
can't.
The filter is for the entire 8 relays.
You need to do the math or use something like the relay activity chart.
Posted: Mon Mar 04, 2013 5:52 pm
by jsclownfish
ahhh, OK. I couldn't figure it out. I guess the json data then represents day, time, and relay status. One of these days I'm going to have to learn about bit math.
Jon
Posted: Mon Mar 04, 2013 6:52 pm
But, as an alternative, you could use one of the custom variables to report the status for a particular relay.
Would that work?
Posted: Mon Mar 04, 2013 7:16 pm
by jsclownfish
That's a good alternative. It's not really critical or anything, I was just curious how the graph would look lining up the light relays with the light sensors.
Posted: Thu Apr 11, 2013 3:26 pm
by arch
This is very useful - thanks.
The custom web chart seems to be picking up the wrong (someone else's?) series labels.
See the attached example for status/chart.aspx?id=arch&filter=T2
First image is custom web chart - with incorrect label "Canopy" - the second image is the Portal web chart with the correct label.
Posted: Thu Apr 11, 2013 3:44 pm
Yeap
Bug
Posted: Tue May 21, 2013 8:39 pm
by mkoryto
Is there a way to graph two or more filters on the custom web chart. Such as filter=T1,WL. If not, can this be added?
Posted: Tue May 21, 2013 9:01 pm
No...
You would have to copy the javascript source code and create your own html page.
Because it is jsonp based, it doesn't really need to be hosted in the server.
Posted: Sun Aug 10, 2014 7:11 am
Has anyone attempted this javascript? I'm playing with my dimming strategy and it would be really useful to overlay my pwm channels and see when each is dimming and coming on, etc.
Roberto, aren't you already doing this with the two graphs already built into the portal? Couldn't you give us a way load more than one param? Or can you point us to the code your using to map the Temps/PH or the relay status?
Thanks in advance
Posted: Sun Aug 10, 2014 8:59 am
I created a page for the new U-App that should work for your purpose:
http://forum.reefangel.com/status/appch ... &filter=t2
You can just append filters.
Posted: Sun Aug 10, 2014 10:02 am
Nice. I'll try it out!
Posted: Sun Aug 10, 2014 10:08 am
Works well but strange because of the not graphing 0s...i might have to adjust my code to shut off at 1% so there's something to graph..
Posted: Sun Aug 10, 2014 10:09 am
by jsclownfish
I don't know if it helps, but Roberto made this example for me awhile ago and I keep icons on my phone and iPad that quickly bring up an assortment of graphs.
http://forum.reefangel.com/viewtopic.ph ... lit=+chart It's nice to use when I just want a quick look at the flow rates, or lighting sensors, I am using.
-Jon
Posted: Sun Aug 10, 2014 10:22 am
lnevo wrote:Works well but strange because of the not graphing 0s...i might have to adjust my code to shut off at 1% so there's something to graph..
Yes, the server doesn't store zeros.
Posted: Sun Aug 10, 2014 10:31 am
The server doesn't have to store zeroes if you filled in the gaps though it would suffice
Posted: Sun Aug 10, 2014 10:33 am
If the server didn't store data, how would it know the timestamp?
Posted: Sun Aug 10, 2014 10:43 am
If your missing data just fill in the missing timestamps with 0...so if at 6am i had 5 and that was the last data, but I'm getting the chart at 7am, we can fill in 0 at 6:05, 6:10, 6:15... We can just assume no data sent would also be 0..good for if controller goes offline and you look at a chart today you will think your WL is just fine since the chart shows 50%...meanwhile your not sending data for 3 days...for example.
Posted: Sun Aug 10, 2014 10:45 am
It also hides when sensors eroneously report 0...like my ph does occasionally...however i cam see when without finding a gap in the timeline..
Posted: Sun Aug 10, 2014 2:12 pm
We would need to analyze the results of the query record by record to be able to do this.
Remember that this is a SQL query.
Posted: Sun Aug 10, 2014 2:23 pm
So how about just biting the bullet then and storing 0 values? You could use NULL value for storing non-sent data.
Posted: Sun Aug 10, 2014 2:50 pm
Your using HighCharts IIRC? I think they have some solutions and its actually opposite of what I said above if I'm interpreting correctly. It asks for you to store the missing data as NULL if you want the x axis to stay consistent.
Posted: Sun Aug 24, 2014 10:48 am
by AlanM
For missing data on HighCharts, here is an example of making the X axis of the chart nice and even which might be uneven in time (Because of 0 values or missed contact with the controller).
http://www.highcharts.com/demo/spline-irregular-time
I don't see what they're doing different from what the portal does in its JS code, though. Maybe it's a later version of the .js than what the portal points to?
Looks like if the data is a series of x,y values, or I assume an array of 2 element arrays. it should do the right thing with the datetime plot.
Posted: Sun Aug 24, 2014 3:26 pm
That seems to be the same way I setup the charts
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8" />
<meta name="format-detection" content="telephone=no" />
<!-- WARNING: for iOS 7, remove the width=device-width and height=device-height attributes. See https://issues.apache.org/jira/browse/CB-4323 -->
<meta name="viewport" content="user-scalable=no, initial-scale=.5, maximum-scale=.5, minimum-scale=.5, target-densitydpi=device-dpi" />
<meta name="msapplication-tap-highlight" content="no" />
<link href='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.css' rel='stylesheet'>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.6.2/jquery.min.js"></script>
<script src='http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.js'></script>
<title>Reef Angel U-App</title>
<script type="text/javascript">
$(function () {
$.mobile.loading( 'show', {
text: 'Connecting to Portal',
textVisible: true,
theme: 'b',
html: ""
Highcharts.setOptions({
global: {
useUTC: false
var seriesOptions = [],
yAxisOptions = [],
seriesCounter = 0,
seriesID = 0,
names = [
'PH'
colors = Highcharts.getOptions().colors;
$.each(names, function (i, name) {
$.getJSON('http://forum.reefangel.com/status/jsonp.aspx?id=reefangel&filter=' + name.toLowerCase() + '&callback=?', function (data) {
var pcolor;
var tname;
var ydec;
var yunit;
if (name == "PH") {
pcolor = '#669900'
tname = 'pH'
ydec = 2
yunit = 'pH'
else if (name == "PHE") {
pcolor = '#447700'
tname = 'pH Expansion'
ydec = 2
yunit = 'pH'
else if (name == "SAL") {
pcolor = '#000066'
tname = 'Salinity'
ydec = 1
yunit = 'ppt'
else if (name == "ORP") {
pcolor = '#330000'
tname = 'ORP'
ydec = 0
yunit = 'mV'
else if (name == "T1") {
pcolor = '#FF0000'
tname = 'Temp 1'
ydec = 1
yunit = '°'
else if (name == "T2") {
pcolor = '#FF8800'
tname = 'Temp 2'
ydec = 1
yunit = '°'
else if (name == "T3") {
pcolor = '#9900CC'
tname = 'Temp 3'
ydec = 1
yunit = '°'
else {
pcolor = '#FF0000'
tname = 'PH'
ydec = 0
yunit = ''
if (data.length) {
seriesOptions[seriesID] = {
dataGrouping: {
smoothed: true
color: pcolor,
tooltip: {
yDecimals: ydec,
ySuffix: yunit
data: data
seriesID++;
// As we're loading the data asynchronously, we don't know what order it will arrive. So
// we keep a counter and create the chart when all the data is loaded.
seriesCounter++;
if(data.length==0)
$('#container').html("No data to display");
$.mobile.loading( "hide" );
if (seriesCounter == names.length) {
createChart();
// create the chart when all data is loaded
function createChart() {
chart = new Highcharts.StockChart({
chart: {
renderTo: 'container',
type: 'spline'
title: {
text: 'Reef Angel Controller Web Chart'
subtitle: {
text: 'Parameters logged for the past 7 days'
credits: {
enabled: false
legend: {
enabled: true,
//align: 'right',
//backgroundColor: '#FCFFC5',
borderColor: 'black',
borderWidth: 2,
//layout: 'vertical',
verticalAlign: 'top',
y: 100,
shadow: true
rangeSelector: {
buttons: [{
type: 'minute',
count: 60,
text: '1h'
type: 'minute',
count: 720,
text: '12h'
type: 'day',
count: 1,
text: '1d'
type: 'day',
count: 3,
text: '3d'
type: 'all',
text: '7d'
selected: 2,
inputEnabled: false
navigator: {
xAxis: {
type: 'datetime',
maxZoom: 3600000, // 1 hour
dateTimeLabelFormats: { // don't display the dummy year
second: '%I:%M:%S %p',
minute: '%I:%M %p',
hour: '%b/%e',
day: '%b/%e',
week: '%b/%e'
xAxis: {
type: 'datetime',
minute: '%I:%M %p',
hour: '%I:%M %p',
day: '%b/%e',
week: '%b/%e'
yAxis: {
plotLines: [{
value: 0,
width: 1,
color: 'silver'
tooltip: {
borderColor: 'silver',
xDateFormat: '%A, %b %e, %l:%M %p',
pointFormat: '<span style="color:{series.color}">{series.name}</span>: <b>{point.y}</b><br/>'
series: seriesOptions
</script>
</head>
<body>
<script type="text/javascript" src="http://forum.reefangel.com/js/highstock.js"></script>
<div id="container" style="height: 500px; min-width: 600px"></div>
</body>
</html>
Posted: Sun Aug 24, 2014 5:15 pm
by AlanM
Right. Is it because you use highstock.js instead of highchart.js? I wouldn't think so, though. Weird.
Posted: Thu Aug 28, 2014 8:13 am
by ganjero
When using this with the pwm channels it uses the same color coding for both channels. Is there a way to change that?
Posted: Thu Aug 28, 2014 8:27 am
I changed it so it uses a random color.
Try it again.
