Dosometric don't work with 0.9.0
Posted: Fri Feb 24, 2012 5:13 pm
by lukeluke
I try to use:
mode 1
ReefAngel.DosingPump1(Port3);
ReefAngel.DosingPump2(Port5);
mode 2
ReefAngel.DosingPumpRepeat(Port3, 0, 360, InternalMemory.DP1Timer_read());
ReefAngel.DosingPumpRepeat(Port5, 10, 360, InternalMemory.DP2Timer_read());
mode 3
ReefAngel.DosingPump(Port3, 1, 23, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 2, 23, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
mode 4
ReefAngel.DosingPump(Port3, 23, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 23, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 17, 10, InternalMemory.DP2Timer_read());
but nothing.... the pump never start...
what can i do ?
Re: Dosometric don't work with 0.9.0
Posted: Fri Feb 24, 2012 5:25 pm
There is a bug :(
I tried fixing it and it made it even worse.
I'll try to check on it this weekend.
Posted: Fri Feb 24, 2012 11:58 pm
by lukeluke
the next time it think that is better create a post with bug list for the new version... for 2 days my balling is stopped ;-)
Posted: Sat Feb 25, 2012 9:53 pm
Please download the latest libraries using the update utility.
http://www.reefangel.com/update
Posted: Sun Feb 26, 2012 2:59 pm
by lukeluke
can i update in other mode ? what do this app ?
i don't want install .net :-D
thanks
Posted: Sun Feb 26, 2012 3:51 pm
Yeah, download from website:
http://reefangel.com/Download.ashx
Posted: Sun Feb 26, 2012 9:33 pm
by projectx
Once you do the library update do you need to regenerate the memory file?
Posted: Sun Feb 26, 2012 10:46 pm
Yes, it is mandatory.
You will get a "No Internal Memory" message in the screen if you don't.
