Problem with Reef Angel - Screen or Controller
Paride0475
Post by Paride0475 »
Hi,
I have some problems with the screen or controller of ReefAngel. Following some pictures:
2012-02-27 22.13.40.jpg (68.93 KiB) Viewed 7262 times
2012-02-27 22.12.48.jpg (51.92 KiB) Viewed 7262 times
2012-02-26 21.34.12.jpg (68.71 KiB) Viewed 7262 times
I tried changing pde and reload it ... reboot the device several times .... disconnect and reconnect temperature sensors....but nothing to be done each time a different problem makes it unusable ...
What happened? any suggestions?
Thanks Paride
Re: Problem with Reef Angel - Screen or Controller
Do you have problems when you have no temperature probes connected too?
Paride0475
When the temperature probes aren't connect the screen appears as in Figure 2012-02-27 22.12.48.jpg (Temp 0.0, Canopy Temp Error, Ambient Temp Error)
Actually, can you reboot the controller while there is no probes connected and let me know if there is any problems?
Paride0475
I reboot without probes connected. The screen remains as previously described in Figure 2012-02-27 22.12.48.jpg
There is nothing wrong on that picture.
Now, plug one probe and reboot.
What happens?
Paride0475
I reboot with one probe connected. After few seconds some noise from relay box and the screen appear like in figure 1.
Does it do the same thing if you use a diffrerent probe too?
Paride0475
Yes, I use different probes and I try to connect in different connectors. :-(
can i see your code?
Paride0475
sure...this is the last version. I'm working on it to simplify because I think the problem could be in the pde
sketch_feb26h.pde
(2.65 KiB) Downloaded 406 times
Try changing this:
  char text[7];
To this:
Does it make any difference?
Paride0475
something should be changed...
Temp 1 seems to be working properly. The visualization is correct.
I switch off, connect the second probe, switch on...Temp 2 is "-2027.-"
Paride0475
after a reboot the problem has reappeared even on temp 1
:cry:
Has it worked in the past?
Does this problem also happen with a simple code on the standard main screen?
Try loading this:
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
Does it do the same thing?
Paride0475
the system has always had some little problem, but I always thought of a programming error code.
a similar problem with preloaded code. Some strange number on the screen in correspondence to temperature. Following the pics:
2012-02-28 20.57.14.jpg (20.71 KiB) Viewed 6176 times
2012-02-28 20.56.20.jpg (23.11 KiB) Viewed 6176 times
now I try with your last code.
Does it happen right away when you boot up the controller?
Paride0475
Unfortunately the problem remains:
2012-02-28 21.16.26.jpg (62.57 KiB) Viewed 6174 times
2012-02-28 21.14.22.jpg (45.43 KiB) Viewed 6174 times
You got a pm
