I have seen various codes for ATO but not for what I am wanting. I would like to have both floats with wires up. one mounted to trigger ATO port on when water/float is down and port off when water/float is up. I would like to have the second float higher and be a backup so no port control when float is down and port off when float is up. having the high/high notify me when it is activated.
Thanks for pointing me in the correct direction.
code for ATO using 2 floats high and high/high backup?
miked
Re: code for ATO using 2 floats high and high/high backup?
You can use this:
The first line implements the ATO and the 2nd line implements the safety.
ReefAngel.SingleATOLow(Port1);
ReefAngel.Relay.Set(Port1,!ReefAngel.HighATO.IsActive());
miked
great, thank you
so this 'port 1' is for whatever port/outlet I have my ATO pump connected to and NOT the ATO plug ins themselves correct. How do I determine which port is the single ato and which is the high.
thank you again
thank you again
