minimum PC requirements
jgriffith
jgriffith
- Contact:
Re: minimum PC requirements
RAGen has all the additional requirements built into it. You just need to run XP or later (like what was already mentioned).
jgriffith
Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
- Contact:
Most everybody uses a PC on here. I personally run Linux (Ubuntu) on my main computer, yet I wrote RAGen. I've actually been wanting to make RAGen cross platform but just have not had the time to do it yet. We shall see what all transpires.jgriffith wrote:Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
