minimum PC requirements
Posted: Fri Mar 02, 2012 1:04 pm
by jgriffith
To download all the files and apps? RAGen and Installer, etc.
Re: minimum PC requirements
Posted: Fri Mar 02, 2012 3:14 pm
I think all you need is .NET 4
Posted: Fri Mar 02, 2012 3:31 pm
by jgriffith
So I guess that means windows XP or later?
Posted: Fri Mar 02, 2012 3:35 pm
Yeah
Posted: Fri Mar 02, 2012 4:35 pm
by binder
RAGen has all the additional requirements built into it. You just need to run XP or later (like what was already mentioned).
Posted: Sat Mar 03, 2012 9:47 am
by jgriffith
Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
Posted: Sat Mar 03, 2012 10:15 am
by binder
jgriffith wrote:Thanks, I use a mac and have the opportunity to buy an older pc laptop for real cheap, it runs XP so it should be good to go. It seems that there are a lot more options with PCs as far as coding the controller.
Most everybody uses a PC on here. I personally run Linux (Ubuntu) on my main computer, yet I wrote RAGen. I've actually been wanting to make RAGen cross platform but just have not had the time to do it yet. We shall see what all transpires.
