Analog vs PWM dimming
Posted: Fri Mar 09, 2012 1:15 am
by billkaza
Hello
I'm Bill
I'm new to your forum. I want to order a RA but i dont know which version to choose for the dimming signal.
I already have 2 x 12v led tapes 1.5m each(8,4W/m) that i power them with a 30w ballast with 1-10v dimmer.
I think my dimmer is analog.I trim it using a small potentiometer.
So if i buy a RA should i choose the Analog signal (20$ more) or should i change my ballast for a PWM dimmer one?
Also which one do you propose to me ?I have heard about meanwells.
Re: Analog vs PWM dimming
Posted: Fri Mar 09, 2012 8:37 am
The analog version should work fine.
Posted: Mon Aug 06, 2012 1:22 pm
Similar question, but I have a LED from China branded by my LFS. They say to just use standard dimmers from Home Depot...does that mean I can use it with the analog dimming? There are no ports for any kind of pwm control.
Posted: Mon Aug 06, 2012 1:23 pm
Are you sure they are dimmable?
Posted: Mon Aug 06, 2012 1:40 pm
I did test them with an x10 module and they did dim... I've asked a few of the guys there and they say they use them there...I have not seen this in person though, but the x10 module did dim them...
Posted: Mon Aug 06, 2012 2:29 pm
Maybe I'm not visualizing it.
How can they dim with just home depot timers? or X10 for that matter.
Posted: Mon Aug 06, 2012 2:59 pm
*shrug* I'm the wrong person to answer, but it does work...
Not sure if it's good long term...hoping someone else would know better.
