Errors after upgrade...
Posted: Mon Mar 12, 2012 4:44 am
by sceia
Ok so I upgraded to the new reefangel 0.9.2 software and updated the libraries as well as getting the new RAGen... I'm getting ready to install the pwnexpansion and dosers. When I try to compile my original file, tons of errors are being thrown... I tried uninstalling and reupdating. I know it's something easy, but I'm lost at the moment...
In file included from LED_Setup.cpp:2:
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel_Globals/ReefAngel_Globals.h:29:22: error: WProgram.h: No such file or directory
In file included from LED_Setup.cpp:18:
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:27:21: error: Globals.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:28:64: error: InternalEEPROM.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:30:25: error: RA_NokiaLCD.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:31:20: error: RA_ATO.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:32:25: error: RA_Joystick.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:33:17: error: LED.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:34:27: error: RA_TempSensor.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:35:19: error: Relay.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:36:20: error: RA_PWM.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:37:19: error: Timer.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:38:20: error: Memory.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:47:17: error: RF.h: No such file or directory
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:82: error: 'RA_NokiaLCD' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:83: error: 'RA_JoystickClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:84: error: 'LEDClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:86: error: 'RA_ATOHighClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:87: error: 'RA_ATOLowClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:88: error: 'RA_TempSensorClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:89: error: 'RelayClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:91: error: 'RA_PWMClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:100: error: 'RFClass' does not name a type
C:\Users\sceia\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:118: error: 'TimerClass' does not name a type
LED_Setup.cpp: In function 'void setup()':
LED_Setup.pde:-1: error: 'class ReefAngelClass' has no member named 'Relay'
LED_Setup.cpp: In function 'void loop()':
LED_Setup.pde:-1: error: 'class ReefAngelClass' has no member named 'LCD'
Re: Errors after upgrade...
Posted: Mon Mar 12, 2012 5:11 am
by symon_say
Didi you upgrade the reef angel installer??
Posted: Mon Mar 12, 2012 8:26 am
Some changes were made to the libraries and if you are using an older code, you will need to slightly restructure.
http://forum.reefangel.com/viewtopic.php?f=7&t=725
If you paste your entire code, I can help you with that.
Posted: Mon Mar 12, 2012 10:42 am
by sceia
rimai wrote:Some changes were made to the libraries and if you are using an older code, you will need to slightly restructure.
Here ya go... I'm about to start tackling the pwm stuff... Buttoning up my build tonight. I have the pwmexpansion port... I'm using the inventronics dimmable drivers. Do I just wire each straight up to the pwmexpansion or should I use the analogue cable?
Scott.
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define AutoTopOff          1
#define Refuge              2
#define MHLight             3
#define Actinic             4
#define WaveController      5
#define Heater              6
#define Fans                7
#define Pumps               8
#define NW1        1
#define NW2        2
#define NW3        3
#define Red        4
#define Green      5
#define Violet     6
#define Blue       7
#define RB         8
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feed Fish";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Day LEDs";
prog_char menu6_label[] PROGMEM = "Actinic LEDs";
prog_char menu7_label[] PROGMEM = "Night LEDs";
prog_char menu8_label[] PROGMEM = "Refuge LEDs";
prog_char menu9_label[] PROGMEM = "100% Daylight LEDs";
menu1_label,
menu2_label,
menu3_label,
menu4_label,
menu5_label,
menu6_label,
menu7_label,
menu8_label,
menu9_label
void MenuEntry1() //"Feed Fish"
  ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
  ReefAngel.ATOClear();
  ReefAngel.DisplayMenuEntry("Clear ATO");
void MenuEntry4()
  ReefAngel.SetupCalibratePH();
void MenuEntry5() //"Day LEDs"
 /* ReefAngel.PWM.SetChannel(0,PWMSlope(9,0,17,0,15,100,60,15));
  ReefAngel.PWM.SetChannel(1,PWMSlope(9,0,17,0,15,60,60,15));
  ReefAngel.PWM.SetChannel(2,PWMSlope(9,30,16,30,15,100,60,15));
  ReefAngel.PWM.SetChannel(3,PWMSlope(9,30,16,30,15,100,90,15));
  ReefAngel.PWM.SetChannel(4,PWMSlope(9,0,17,0,15,75,30,15));
  ReefAngel.PWM.SetChannel(5,PWMSlope(11,0,14,0,15,30,20,15));
void MenuEntry6() //"Actinic LEDs"
void MenuEntry7() //"Night LEDs"
void MenuEntry8() //"Refuge LEDs"
void MenuEntry9() //"100% Daylight LEDs"
  //Init and custom menus
AutoTopOff          1
Refuge              2
MHLight             3
Actinic             4
WaveController      5
Heater              6
Fans                7
Pumps               8
    //Menu Modes
    ReefAngel.FeedingModePorts = B10010000;
    ReefAngel.WaterChangePorts = B10010000;
  //Pumps and waves on
  ReefAngel.Relay.On(Pumps);  //Turn Sump/Skimmer on at startup
  ReefAngel.Relay.On(WaveController);  //Turn WaveController on at startup
  ReefAngel.LCD.SetContrast(60);  // Set contrast to 60
  //Top Off
  ReefAngel.StandardATO(AutoTopOff,500);  //Setup AutoTopOff as Auto Top-Off function with 500s timeout
  //Light Schedule
  //Heating/Cooling
  ReefAngel.StandardHeater(Heater,778,782);  // Setup Heater to turn on at 77.8F and off at 78.2F
  ReefAngel.StandardFan(Fans,780,790);  // Setup fans
  ReefAngel.Relay.Write();  // Make relay changes effective
Posted: Mon Mar 12, 2012 11:17 am
by rufessor
You can fix a lot of the errors if you just look at the post Roberto suggested and change the names used in the
#include lines at the top....
Many of the files that used to be called ReefAngel_XXX.h are now either RA_XXX.h or something else entirely. Its super easy, if you do not know how to code, you could change those at least. The rest is probably only a few lines that require attention that I am sure Roberto will reply with fixes. At least you'll be 95% fixed if you just change names of the #include <file names edit in here>
There is a 1:1 listing of old names (which you are using) and new names (which you need to switch to) in the post Rimai referenced.
Posted: Mon Mar 12, 2012 11:28 am
Yeap, just changing the headers up top should fix everything:
#define Refuge              2
#define MHLight             3
#define Actinic             4
#define Heater              6
#define Fans                7
#define Pumps               8
#define NW1        1
#define NW2        2
#define NW3        3
#define Red        4
#define Green      5
#define Violet     6
#define Blue       7
#define RB         8
#define CUSTOM_MENU
menu1_label,
menu2_label,
menu3_label,
menu4_label,
menu5_label,
menu6_label,
menu7_label,
menu8_label,
menu9_label
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
AutoTopOff          1
Refuge              2
MHLight             3
Actinic             4
WaveController      5
Heater              6
Fans                7
Pumps               8
    //Menu Modes
  //Top Off
  //Light Schedule
  //Heating/Cooling
Posted: Mon Mar 12, 2012 11:53 am
by sceia
Yea, I guess that's what happens when you wake up at 3am cause you can't sleep and want to program...lol... It did fix most errors... But I still have one...
ledsetup.cpp: In function 'void setup()':
ledsetup:135: error: 'class ReefAngelClass' has no member named 'InitMenu'
Posted: Mon Mar 12, 2012 12:40 pm
Open RAGen
Go to features tab
Check Custom Menu and uncheck Simple Menu
Save
