Customized ino
Posted: Mon Mar 12, 2012 2:46 pm
by rafamar
Hi
ive get and customized this code
// Autogenerated file by RAGen (v1.2.1.158), (03/12/2012 21:21)
// RA_031112_2121.ino
#define SIMPLE_MENU
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#define Heater              1
#define ATO                 2
#define Skimmer             3
#define Pompa Sx            4
#define Bianchi             5
#define Blue                6
#define Pompa Grande DX     7
#define Pompa Piccola DX    8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, "                       "); //Top Banner
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " Raffa's Reef "); //Top Banner
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
  // Display the T1 temp value 10,22
  //char text[7];
  //ConvertNumToString(text, ReefAngel.Params.Temp [1], 10);
  //ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
  //ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 22, text, Num8x16);
  //pingSerial();
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,100,12,"pH");
  // Display pH Value
  //ConvertNumToString(text, ReefAngel.Params.PH, 100);
  //ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
  //ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 22, text, Num8x16);
  //pingSerial();
  // Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
  // Display the Actinic PWM channel value at 90,40
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 40, 1);
  // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
  // Display the Daylight PWM channel value at 90,50
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 50, 1);
  // Display T2 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,60,"Ambient Temp");
  // Display the T2 temperature value at 90,60
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp [2], COLOR_CORNFLOWERBLUE, 90, 60, 10);
  // Display T3 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,70,"Sump Temp");
  // Display the T3 temperature at 90,70
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp [3], COLOR_CORNFLOWERBLUE, 90, 70, 10);
  // Display Vortech MP10ew Mode Text at 90, 80
  //ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart Mode");
  // Display EcoSmart Mode Value
  //ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
  //#if defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params,
    //ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
  //#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params);
  //#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
// ReefAngel.LCD.DrawGraph(5,7);
  ReefAngel.FeedingModePorts = B00100001; //Ports 6 & 1 turn off
  ReefAngel.WaterChangePorts = B00000111; //Ports 2 & 1 & 3 turn off
  ReefAngel.OverheatShutoffPorts = B00011000; //Ports 4 & 5 turn off
  ReefAngel.LightsOnPorts = B00110000; //Ports 6 & 5 turn on
  ReefAngel.Relay.On(Port4);
  // Delay Skimmer port 5 minutes whenever turned on
  // From Curt - THANKS CURT!
  ReefAngel.Relay.DelayedOn(Port3, 2);
  //Heater
  ReefAngel.StandardHeater(Heater,750,770);  // Setup Heater to turn on at 77.5F and off at 78.0F
  //Lighting schedule
  ReefAngel.StandardLights(Bianchi,14,0,23,30);  //Daylight schedule 14:00am - 23:30pm with 0min cool down
  ReefAngel.StandardLights(Blue,13,30,23,59);  //Actinic schedule 13:30am - 23:59pm
  //ReefAngel.StandardLights(Refugium,19,0,7,0);  //Refugium schedule 7:00pm - 7:00am
  // Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
  //From Roberto - THANKS ROBERTO!
   /* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1)  //Alk Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump1);  //Turn Alk Doser on
      ReefAngel.Relay.Off(DosingPump1);  //Turn Alk Doser off
    if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1)  //CA Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump2);  //Turn CA Doser on
      ReefAngel.Relay.Off(DosingPump2);  //Turn CA Doser off
  // Dosing pumps
  // From Roberto - THANKS ROBERTO!
  //if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
    //ReefAngel.Relay.On(DosingPump1);  //Turn DosingPump1 Doser on
  //else
   // ReefAngel.Relay.Off(DosingPump1);  //Turn DosingPump1 Doser off
  //if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
   // ReefAngel.Relay.On(DosingPump2);  //Turn DosingPump2 Doser on
  //else
    //ReefAngel.Relay.Off(DosingPump2);  //Turn DosingPump2 Doser off
  // Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  if (hour()>=01 || hour()<07)
      ReefAngel.PWM.SetActinic(MoonPhase());  //Moon phase schedule between 7:00pm - 7:00am
      ActinicPWMValue=PWMSlope(13,30,22,30,0,100,60,ActinicPWMValue); //Actinic turn on at 13.30am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
      //ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
  DaylightPWMValue=PWMSlope(14,00,22,59,0,90,60,DaylightPWMValue); //Daylight turn on at 14am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(16,30)
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,30)
#define Lightning_Change_per_Cloud 25
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  //When cusotm menu Force cloud is selected
  if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,113,132,121);
    ReefAngel.LCD.DrawText(0,255,12,113,"C");
    ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,52,113,"L");
    ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
      int x=0;
      if ((cloudstart/60)>=10) x=18;
      else x=24;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
      if ((cloudstart%60)>=10) x=36;
      else x=42;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
      else x=94;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
      else x=112;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
from my pde/ino section
but when i try to compile it i recived this message
Binary sketch size: 31698 bytes (of a 30720 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1651)
at processing.app.Sketch.build(Sketch.java:1570)
at processing.app.Sketch.build(Sketch.java:1546)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1845)
at java.lang.Thread.run(Thread.java:619)
could you help me?
thx
Re: Customized ino
Posted: Mon Mar 12, 2012 3:48 pm
by wolfador
you are out of memory, try turning off the #define VersionMenu. You only need a little bit of space. If you still need more do a custom menu.
Re: Customized ino
Posted: Mon Mar 12, 2012 4:27 pm
by rafamar
now it give me this error
ReefAngel\ReefAngel.cpp.o: In function `ReefAngelClass::ProcessButtonPressCustom()':
C:\Users\Raf\Documents\Arduino\libraries\ReefAngel/ReefAngel.cpp:2047: undefined reference to `MenuEntry1()'
what is means??
Re: Customized ino
Posted: Mon Mar 12, 2012 4:38 pm
It means that you are trying to use custom menu, but don't have the correct things in the code.
There is a good manual on how to get started:
http://forum.reefangel.com/viewtopic.php?f=14&t=311
Re: Customized ino
Posted: Tue Mar 13, 2012 2:22 am
by rafamar
ive see guide, that is for old library....
so it seems code is ok..!
i cant see error, could you help me to found it?
thx
Re: Customized ino
Posted: Tue Mar 13, 2012 4:49 am
by wolfador
rafamar wrote:Roberto,
thx
did you update your features.h to enable to custom menu?
In your .ino the custom menu should look like
 // Create menu entries
 prog_char menu1_label[] PROGMEM = "Spot Feeding";
 prog_char menu2_label[] PROGMEM = "Flow Feeding";
 prog_char menu3_label[] PROGMEM = "Water Change";
   menu1_label, menu2_label, menu3_label};
 void MenuEntry1()
   ReefAngel.FeedingModePorts = B00001100;
   ReefAngel.FeedingModeStart();
   void MenuEntry2()
   ReefAngel.FeedingModePorts = B00001000;
  void MenuEntry3()
Inside of the void setup() you should have:
