Trying to use oF and oC on my display...
Posted: Fri Mar 16, 2012 10:28 am
by sjmusic2
I am trying to include temp probe data converted to oC in addition to my oF already displayed and it feels like it should be very easy but I can't seem to figure it out !
int T2C;
float T2C2;
T2C=ReefAngel.Params.Temp2;
T2C2=((float)T2C-32.0)*0.56;
ConvertNumToString(text, T2C2, 10);
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 95, 65, T2C2);
Thanks in advance.
Re: Trying to use oF and oC on my display...
Posted: Fri Mar 16, 2012 12:42 pm
by binder
If you are using 0.9.X libraries, you have to use this:
This is what we use when we convert from C to F initially:
You also must remember that the value stored in the Temp variable does not contain a decimal point. So 80.0 is actually stored as 800. You code would need to look like this:
It may need to be tweaked a little more, but that should get you going.
Posted: Sat Mar 17, 2012 8:14 am
by sjmusic2
I'm not using 0.9 yet, so this is where I ended up...just posting for reference (I added a degree graphic with PutPixel as I'm unaware of a font charcter already in existance) :
int T2C;
int T2C2;
//This is inserted into DrawCustomMain...
//Convert and display LED array in Celsius
T2C2=((float)T2C-320)*0.56;
ReefAngel.LCD.DrawText(COLOR_OLIVEDRAB,DefaultBGColor, 95, 79, text);
ReefAngel.LCD.DrawText(COLOR_OLIVEDRAB,DefaultBGColor, 70, 79, "C");
ReefAngel.LCD.PutPixel(70, 66, 79);
ReefAngel.LCD.PutPixel(70, 67, 79);
ReefAngel.LCD.PutPixel(70, 65, 80);
ReefAngel.LCD.PutPixel(70, 65, 81);
ReefAngel.LCD.PutPixel(70, 66, 82);
ReefAngel.LCD.PutPixel(70, 67, 82);
ReefAngel.LCD.PutPixel(70, 68, 80);
ReefAngel.LCD.PutPixel(70, 68, 81);
I could probably have done the conversion in one step to save code, but I have plenty of free space so I made it easier to read instead
Posted: Thu Mar 22, 2012 1:57 pm
by binder
I forgot I had this stuff inside the libraries...
#define CONVERT_TO_C(x) ((x) - 320)/1.8
#define CONVERT_TO_F(x) ((x) * 1.8) + 320
it could be simplified or changed so there's no division being performed, but still.
You could then use:
T2C2 = CONVERT_TO_C(ReefAngel.Params.Temp2);
Then the compiler would handle all the code behind the scenes.
Posted: Mon Mar 26, 2012 8:30 pm
by sjmusic2
Just saw this new info, thanks, every byte saved is much appreciated
Posted: Tue Mar 27, 2012 3:27 pm
by binder
sjmusic2 wrote:Just saw this new info, thanks, every byte saved is much appreciated
Cool.
