hi! i would like to share a great roberto contribution.
since i don't like wavemaker function ( i prefer use 2 pumps alterating every 6 hours) here is a simple workaround:
roberto wrote:
Just because it says standardlight doesn't mean it should only be used for lights.
You could use it like this:
ReefAngel.StandardLights(Relay4,6,0,12,0);
if (bitRead(ReefAngel.Relay.RelayData,Relay4)==0) ReefAngel.StandardLights(Relay4,18,0,0,0);
Try it and let me know if it works.
this will power up relay4 from 6:00 am to 12:00am and from 6:00pm to 12:00pm
doing the same with another relay will alternate 2 pumps every 6 hours...
it works well!
thanks!
wave pump started by hour and minutes instead wavemaker func
mantu
alexwbush
Re: wave pump started by hour and minutes instead wavemaker
should that read StandardLights?
mantu
i don't understand you.. sorry...alexwbush wrote:should that read StandardLights?
There was a typo on your post. That's all.mantu wrote:i don't understand you.. sorry...
You typed StandarLights and he was saying it should've been StandardLights.
alexwbush
I was just trying to clear it up in case someone copied and pasted and then was wondering why it might not work.
Thanks for posting!
Thanks for posting!
mantu
alexwbush wrote:I was just trying to clear it up in case someone copied and pasted and then was wondering why it might not work.
Thanks for posting!
i'm sorry! i just edited original post!
tnx!
Lorenzo
